piston rings
Old Feb 11, 2007 | 12:52 PM
cozzy's Avatar
cozzy
Default piston rings
is it possible to put new piston rings in without removing engine ....i mean can i remove the sump and remove th piston from the bottom
Old Feb 11, 2007 | 02:31 PM
Alvyn's Avatar
Alvyn
Default Re: piston rings
to your 1st Question yes you can(once heads off) to the 2nd Question no you cant(how would you clamp the rings)!
Old Feb 11, 2007 | 04:34 PM
cozzy's Avatar
cozzy
dont no mate thats why i asked
Old Feb 12, 2007 | 01:40 PM
SafeChav's Avatar
SafeChav
You can't remove the pistons from the bottom of most blocks anyway as there is usually a step at the end of the bore!
If you take the head and the sump off then you can do it in situ without removing the block etc?
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
