CHATTER !!!!!!!
Old Feb 11, 2007 | 09:11 AM
s2 300bhp's Avatar
s2 300bhp
Default CHATTER !!!!!!!
how do/can i make my rs chatter does this makes sence
Old Feb 11, 2007 | 09:32 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Convert to EFi.
ERST's chatter, infact every turbo chatters to an extent as the throttle closes and the air is forced backwards through the compressor blades. It is the sound of the blades 'chopping' the air that can be heard. The chatter from the ERST turbo is muffled by the fact that there is a metering head and an air filter for the sound to pass through, so it can only vaguely be heard.
Make sense?
So, by getting rid of the metering head, you will hear the chatter!
Old Feb 11, 2007 | 09:50 AM
s2 300bhp's Avatar
s2 300bhp
is there a lot of work involved to do this or would it just be a waste of time. iv heard other rs's chatter i think it sounds nice but unsure on the work that has to be done thanks
Old Feb 11, 2007 | 09:55 AM
Christian and Beccy
#1 in Spelling Club
It's alot of work just to be able to hear chatter.
A full management conversion is needed, which will cost well over Ł1k.
Old Feb 11, 2007 | 09:59 AM
s2 300bhp's Avatar
s2 300bhp
scrap that then thanks for ya help
Old Feb 11, 2007 | 10:38 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
What do you guys think about my little theory?
I guess you'd be able to get chatter if you put a dump valve on and put a bleed valve into the vacuum hose that's controlling the d/v. Bleed away most of the air so that the piston in the dump valve is only opening a tiny little bit when on vacuum and therefore allowing the "sound" to escape, yet maintaining enough pressure inside the hoses to stall the compressor wheel.
Old Feb 11, 2007 | 11:52 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine chatters well for MFI and only 7psi - somethings probably fucked
Old Feb 11, 2007 | 12:15 PM
s2 300bhp's Avatar
s2 300bhp
hope not lol
Old Feb 11, 2007 | 12:20 PM
vroooom ptssssh
It Wasnt Me!
Ditto that
Old Feb 11, 2007 | 12:47 PM
davsmith64's Avatar
davsmith64
ive converted to EFI, the chatter sounds cool.. but didnt cost me 1k to convert,
i managed to snap up a FRST engine loom and sensors , ECU, and chip all for Ł160.. inlet manifold and complete head for Ł60.. pedal was already converted,, all in it cost me about - Ł300 maybe less...
well worth the money too... made a massive difference to MFI..
Old Feb 11, 2007 | 01:46 PM
RST Ski's Avatar
RST Ski
same ere! kept me mfi head though, got a adpter plate on mine instead, starts first time in the mornings now
Old Feb 11, 2007 | 02:55 PM
smitsturbo's Avatar
smitsturbo
ive been offerd a cheep 1600 xr2i can i use the inlet,head,loom etc to do an efi conversion on my s1 obviosly i'll need the frst ECU but apart from that will that be ok....just thinking about it while its in bits
Old Feb 11, 2007 | 03:03 PM
MJC's Avatar
MJC
Mine chatters well on Mfi
Old Feb 11, 2007 | 05:28 PM
s2 300bhp's Avatar
s2 300bhp
i have a escort on a m-reg its a 1.6 16v zetec mfi could i ues this ??????
Chas
Sep 21, 2015 08:57 PM
nice_head
76
Aug 22, 2005 09:17 AM
thelynx
Feb 26, 2005 10:33 PM
DaveRS
Feb 3, 2005 04:59 PM
MadMac
56
Jan 7, 2005 09:09 PM
