MK5 Escort SI Ghia has Amplifier as standard - need an ISO
Old Feb 10, 2007 | 08:29 PM
Nash_mr2's Avatar
Nash_mr2
Default MK5 Escort SI Ghia has Amplifier as standard - need an ISO
My car is MK5 Escort SI Ghia
I has the Standard ford amplifier behind the Glove box on the passanger side.
i pulled the stereo out (standard ford) and it has only the power leads on the back and 1 plug - the other wire runs into the amp (speakers) which is of a shape i've never seen before!?
Is there an ISO Adapter for the cars with the standard ford amplifier system?
Old Feb 10, 2007 | 08:37 PM
iansoutham's Avatar
iansoutham
OCD Victim
Yep. You can get it from any good audio shop or Halfrauds. Is about Ł22 from Halfrauds. You will need the ISO lead set for a 2007 setup.
Make sure though that the lead plugs in fully for the speaker / amp part. It can be awkward.
Old Feb 10, 2007 | 10:15 PM
Nash_mr2's Avatar
Nash_mr2
cool i'll go to halfords tomorrow.
By the way, what did you mean buy the 2007 part?
Old Feb 11, 2007 | 08:42 AM
iansoutham's Avatar
iansoutham
OCD Victim
The radio is a 2007 model. It has no built-in amplifier.
There was also a 2008 model, but that had different connections as it also had a single-slot CD player underneath.
Old Feb 11, 2007 | 09:04 AM
crash_ash's Avatar
crash_ash
my cossie has an amp behind glovebox, couldn't get a lead for it. so i had a look at the amp, where the speakers plug into the amp it is a normal fod connection (like the one that connects the speakers to a non-amp head unit)
I bought a normal ford -> iso adaptor and soldered in some extension wires and connected the speakers there.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
