std series 2 brake discs?
Old Feb 10, 2007 | 08:06 PM
mk3cable's Avatar
mk3cable
Default std series 2 brake discs?
what size are std series 2 brake discs. cheers
Old Feb 10, 2007 | 08:27 PM
xr_craig's Avatar
xr_craig
260mm i think
Old Feb 10, 2007 | 08:38 PM
iansoutham's Avatar
iansoutham
OCD Victim
260mm standard. Same as all 2wd ABS Sierra and Granada models up to 1994 (exc. Cosworth).
Old Feb 11, 2007 | 07:14 AM
260mm.
NOT the same as all sierra ABS, 1.8 87-93 was 240mm.
Granada also used up to 94 262mm and 278mm.
Old Feb 11, 2007 | 08:48 AM
iansoutham's Avatar
iansoutham
OCD Victim
Originally Posted by tabetha
260mm.
TwinCam and V6 non-Cosworth Sierra & Granada had 260mm (or 258.2 if you want to be pedantic). 278mm was reserved for 4x4 Sierra Cosworths and posible some 4x4 Granadas. You will note that I stated 2wd cars. I have never yet seen a 1.8 Sierra with ABS.
BTW Tabetha: you have caused enough trouble on all other forums you enter. Please do not reply to my posts as you talk out of your posterior most of the time (notice that fact that I do not swear @ you unlike what you do on all the forums YOU visit).
ATTN: Any mods who wish to discuss this "rant" with me, feel free to do so by pm, I will explain everything for you. I WILL NOT elaborate on the forum though.
Back to topic now.... (sorry mk3cable)
Old Feb 11, 2007 | 03:14 PM
callumw's Avatar
callumw
... and nobody mention power tools
Old Feb 11, 2007 | 05:43 PM
iansoutham's Avatar
iansoutham
OCD Victim
Old Feb 11, 2007 | 05:55 PM
EBC CATALOGUE 2004/5 PAGE 59.
SIERRA 1.8 ABS PART NUMBER D086 240MM
So anyone can look this up if they so feel the need, only trying to make sure that no one buys the wrong discs, sorry it appears to be wrong to do this.
And no I will not lay down and be quiet, if someone does not wish to read what I print then don't, it's fairly simple I would have thought.
ps I have never seen on of these either, but as discs are made I would imagine they do exist
Old Feb 11, 2007 | 08:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you look in some of the sierra handbooks, you will see a 1.8 sierra with abs
the S2's used the same brakes as the sierra's that had abs (and the same size as those that had discs all round)
they are the same size on the granadas but they have an extra hole in them to acomodate the extra stud in the hubs
don't buy sierra 4x4 discs as they run a different offset
don't buy sierra cosworth 2wd discs as they won't bolt on without a spacer bracket
don't buy sierra cosworth 4x4 discs as they are so the wrong offset
the calipers on the granadas and the sierras that use the 260mm discs are the same as on the S2 so if you want to upgrade to 260's and DON'T feel the need to go and look for abs specificly equied sierras, just go and get the ones from a granada
Old Feb 11, 2007 | 08:17 PM
dojj's Avatar
dojj
ah yes, the infailable "book" of stuff that they keep behind all parts desks, the same sort of book that lists the 24V pads as being the same as the normal granadas, the same books that list the front inner cv gaitors for the 4wd fords as being the same as the rears, the same books that list all sierra estate shocks as being the same, the same books that list all sierras without abs as having 240mm front discs and rear drums, the list could go on for a few pages yet, but take it from me, all uk sierras that had abs used 260mm front discs and 253mm rear discs
Old Feb 11, 2007 | 09:57 PM
slickescort1981's Avatar
slickescort1981
WELL SAID!
Old Feb 12, 2007 | 06:32 AM
The public might beleive and trust what a manufacturer says rather than assume they are wrong though it would seem quite normal, granted they nmay from time to time get things wrong, as I SAID I HAVE NEVER SEEN A 1.8 WITH ABS, I merely qouted from book of words and gave the book qouted from, so that I was not misleading anyone.
Old Feb 12, 2007 | 10:24 AM
martysport's Avatar
martysport
Don't forget yer B&D Tabetha
Old Feb 12, 2007 | 03:47 PM
dojj's Avatar
dojj
never said you did mate, just pointing out that they do contain various mistakes, and they can't cover every eventuality
i'll get the 1.8 abs thing up in a mo
Old Feb 12, 2007 | 04:22 PM
dojj's Avatar
dojj
both pictures kindly donating from my sierra handbook thank you henry
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
