S2 Gear box whine
Old Feb 10, 2007 | 07:48 PM
Moose's Avatar
Moose
Default S2 Gear box whine
Rite it whines when in second really badly only when you not accelerating,
also in 3rd and 4th but it not as loud, would it be an oil problem or has
the gear box had it? cheers for any help
Rich
Old Feb 10, 2007 | 08:39 PM
iansoutham's Avatar
iansoutham
OCD Victim
Sounds like the bearings are on the way out. The box is whining because the slack is not being taken up as it would when accelerating hard. You could check the oil, but I suspect, even if it was low, you would only be prolonging the inevitable.
Old Feb 10, 2007 | 08:42 PM
Moose's Avatar
Moose
bugger what would be best replacement? diesel box wi the lsd in or
go for another s2 box? cheers
Old Feb 10, 2007 | 08:47 PM
iansoutham's Avatar
iansoutham
OCD Victim
Bear in mind that a Diesel box is no stronger than a normal one, just has higher ratios. Depends on money, if you can afford it, you can get the boxes rebuilt using the MK5 bearings, as they are slightly beefier, but I think you have to change a lot of other internals as well, so probably not cost-effective. I know the Rapid-Fit bloke @ the Ford dealers I used to work in looked @ this method, would have cost over £1k in bits @ staff rate.
Or easier, just find another box and run that. Remember though, if the bearings have gone / are going, then the LSD diff probably ain't gonna be that healthy anyway.
Probably best to have a word with Paul @ North Yorks RS Spares. He probably has hundreds of them holding up the foundations in his place.
Old Feb 10, 2007 | 08:50 PM
Moose's Avatar
Moose
cheers mate will drop him a pm
Old Feb 11, 2007 | 11:39 PM
Grandad racer's Avatar
Grandad racer
s2 gear boxes are a bit thin on the ground now, diesal boxes are the next best thing . iwas told 300£ to fix my turbo box, so i bort a dieasel for 30£. to be honist i cant realy tell the differance
Old Feb 12, 2007 | 04:13 PM
JamboRS's Avatar
JamboRS
focus rs 1672
wait till you try and power out a bend on boost
Old Feb 12, 2007 | 10:48 PM
Grandad racer
have a look at fast ford mag, march edition. lists top 10 rare rs spares, at number 2 is escort rs turbo gear boxes, till i can find one, the dieasl is agood substitute the mag says people are going for xr3i boxes, bad news,no lsd, and mutch lower gear ratios.hope this helps!!!
Old Feb 13, 2007 | 07:06 AM
iansoutham's Avatar
iansoutham
OCD Victim
Or ask for finis number 1117975 @ your local Ford dealer. Expect price to be around £5-600.
3.82 ratio Escort Turbo gearbox, may need replacement release bearing finis 6847097. @ least there is a guarantee and if it breaks, Ford will pay to replace it.
Old Feb 15, 2007 | 11:07 PM
Grandad racer
Grandad racer
s2 escort turbo
Old Feb 15, 2007 | 11:11 PM
Grandad racer
Grandad racer
ok i aint got lsd, but at least im still on the road
Old Feb 21, 2007 | 07:27 PM
Moose's Avatar
Moose
fitted a diesel box still goes well cant fault it, dint see much difference in engine speed when cruisin at bout 70 was about 250 rpm lower at the most, and now i have chance to give the car some abuse lol i get to 90 and my boost drops to bout 2 psi, anyone got any clues? is it most likely to be the amal valve cos i was thinkin if it was the actuator surley it would hold boost at all?
Rich
Old Feb 21, 2007 | 07:30 PM
Moose's Avatar
Moose
oh yeah the oil that came out of my old box was well past it, every one who came into work the next day was complainin sayin the could smell gas so you can imagine what it was like when it first came out, also the oil was lookin similar to a copper paste solution it was really meatalic
Old Feb 24, 2007 | 01:39 AM
Grandad racer
hi, carnt help with your boost prob, soz, but im glad your happy with your dieasl gear box, they realy are the best alternative!!
tankybaby66
Feb 6, 2016 02:24 PM
AJC
Oct 8, 2015 11:09 AM
mondeomark
Sep 28, 2015 06:28 AM
Russ Payne
Sep 25, 2015 08:29 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
