Breather question (urgent help needed plz)
I just need to check some think about the pipe arrangement
1.. hose from the top of the breather to the rocer cover
1.. hose from the top of the breather to where the kidney box was
1.. hose from the drain on the breather to under the turbo where the bolt is
and i also need to know if any1 knows what thread the bolt is under the turbo and where ecatly it is as i heard there are two (1 for oil and 1 for water)
also do i need to remove the kidney box or can i conect it to the breather?
please help me
please help me
ok
some more questions..
where is hose nr5 going ? to the picture below ? is the elbow included in kit ?
and 2 different drawings... with an extra breather pipe nr 6 , is that diff between rwd and 4x4 ?
and the catch tank is positioned where ?
how empty it ?
is this available at ford ?
why was this not standard
how empty it ?
Originally Posted by cossie 350
ok
how empty it ?
how empty it ?
Hose number 5 in the above pic will return any oil to the sump
The kit shown is from the Group A build manual - it'll give you an idea of the layout that you can replicate with an after-market breather kit - follow their own fitting instructions
what is the best kit available ?
it has to be good !
bailey ? ggr ?
ok
i bought the bailey kit
not 1 hose fits
how come ?
also where do you fit the tank to ? (pics please
in the motorsport kit the oil return is on the turbo side
in the bailey kit there are 2 breather hoses (1 on turbo side and 1 where kidney box was)
and the oil return is the small one from kidney box
not 1 hose fits
how come ?
)in the motorsport kit the oil return is on the turbo side
the pipe that goes into the top of the cam cover can that be situated anywhere else cause ive just had my cam cover painted and forgot to ask him to fit a port before he painted it
JoeyBoyden
Aug 18, 2015 10:52 PM
