Roof Skin
Old Feb 8, 2007 | 04:14 PM
AJ_ERST's Avatar
AJ_ERST
Default Roof Skin
Just wondered if anybody has put a new skin on there s2 - if so how did you go about it?
Old Feb 8, 2007 | 04:27 PM
antony215's Avatar
antony215
Escort Rs Turbo
It aint an easy job heres a link that might help you
http://northlincsrsoc.proboards29.co...ead=1102080320
Old Feb 8, 2007 | 04:38 PM
AJ_ERST's Avatar
AJ_ERST
Thanks for the info , couldnt find any info about this anywhere, wish I hadnt asked now as it looks like quite a job Mines not too bad just a few spots appering, been told I might be able to spot weld these and then fill and paint?
Old Feb 8, 2007 | 05:42 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Sorry to piss on your chips, but I'm afraid that if you have rust spots, that's it. New roof is the only way.
Wait until you look down the sunroof cavity with a torch. <<<Real tears
Old Feb 8, 2007 | 05:43 PM
antony215's Avatar
antony215
Escort Rs Turbo
Ive herd that spot welding warps the roof im sure someone said that filling the holes with lead is a better way to do it
Old Feb 8, 2007 | 07:01 PM
MJC's Avatar
MJC
You can't get new roof skins from Ford anymore either
Old Feb 8, 2007 | 09:41 PM
AJ_ERST's Avatar
AJ_ERST
Its a shame as the rest of the car is totally solid... someone said as long as you spot weld one at a time and let it cool in-between the roof shouldnt warp! think I might go down the filling with lead path, sounds safer
Old Feb 8, 2007 | 09:51 PM
Christian and Beccy
#1 in Spelling Club
I'm afraid you will be disappointed. Once the sunroof is removed and you look in the cavity between the inner and outer panels, you will be shocked.
To lead-load it will need to be back to good metal and to do this will be when you find the problems.
Old Feb 8, 2007 | 10:27 PM
AJ_ERST's Avatar
AJ_ERST
Thanks I feel much better for your positive comments!!!
Old Feb 8, 2007 | 11:29 PM
antony215's Avatar
antony215
Escort Rs Turbo
As christian says they may only look small now it's when you start to take it back to good metal when you really find out how bad it is Im sure TonyTurbo done his the way your on about ill see if i can find the picture's of his.
Old Feb 8, 2007 | 11:42 PM
Rs Baz's Avatar
Rs Baz
ive done 2 roof's but thay are a twat too do no point in welding it it does
warp then you spend a day trying to fill it and sand it to the same shape as the roof......
ive got one in my workshop now rotton roof ive found it its been bodged with another one placed on to of it a real wank job
ford still do the roof skins but there around £300
Old Feb 9, 2007 | 12:00 AM
antony215's Avatar
antony215
Escort Rs Turbo
TonyTurbo's roof some proper work him and damo put in on it
only picture i could find of the roof painted without going through all 56 pages of the thread
As you can see from above not a 5 min job even when you dont take the roof off
Have a look at the thread mate well worth a read/look tony and damo done some proper top work on tony's car
https://passionford.com/forum/viewto...asc&highlight=
Old Feb 9, 2007 | 12:02 AM
AJ_ERST's Avatar
AJ_ERST
Thanks for all your comments guys, think I will try the lead root to keep rust at bay for now! looks like a new roof to sort it propely then.
Old Feb 9, 2007 | 12:10 AM
AJ_ERST's Avatar
AJ_ERST
Thanks for that antony star man
Old Feb 10, 2007 | 11:02 AM
Rick's Avatar
Rick
i did the same as tony's. It was fun putting 'fresh' holes in the roof!
SMILER258
Sep 28, 2015 09:04 AM
oldskooldanrst
Sep 27, 2015 04:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Neil Clark
Sep 8, 2015 07:06 PM
