Oil leak on new engine..
Old Feb 7, 2007 | 08:40 AM
Mk2_2dr_2L_Escy's Avatar
Mk2_2dr_2L_Escy
Default Oil leak on new engine..
Hi all,
I just recently rebuilt a cosworth engine and an oil leak became apparent after running the engine for a while.. After checking everything i decided to take the motor back out, and it appears to be the head gasket leaking oil out the back of the engine..
Has anyone got any ideas as to why this would occur ?? the gasket is a GPA item from burton power and the engine is fresh, i payed to have the bottom end professionally assembled and i had the head surface ground and checked out b4 i put it together an on to the block, I am using ARP head studs.
Any help would be greatly appreciated.
Thanks,
Damion.
Old Feb 7, 2007 | 11:02 AM
fatmike's Avatar
fatmike
did u torq it down in the right bolt tighaning patern ? also was the block skimed or checked to see if it was flat befor asembaling?
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
