uprated injectors for 2lt Zetec engine
Old Feb 6, 2007 | 10:04 PM
Zetechamo's Avatar
Zetechamo
Default uprated injectors for 2lt Zetec engine
Can anyone help me, I am currently building a 20lt Zetec (silver top) engine to get about 200BHP out of it. I am having problems identifying any injectors that will go into the original Zetec injector rail (being side fed) are there any injectors that I can use without having to replace the injector rail.
Old Feb 7, 2007 | 03:35 AM
JesseT's Avatar
JesseT
There's plenty. Easiest to source is probably the Nissan SX200/SX240 injectors(S13/S14) or aftermarket injectors to almost any Nissan sportscar.
Old Feb 7, 2007 | 02:42 PM
Zetechamo's Avatar
Zetechamo
Thanks for the reply. Will these Nissan injectors go straight into the original Zetec fuel injector rail, otherwise it means having to install a new fuel injection system.
Old Feb 7, 2007 | 03:38 PM
ram's Avatar
ram
Has a large member
no reason why they shouldnt, all injectors are the same size as far as i know?
Old Feb 10, 2007 | 07:06 AM
Wardy257's Avatar
Wardy257
The standard ZETEC inlet only flows enough for around 150 bhp in a NA set up. Unless you are going turbo it will need changing.
You may also fing the injector are positioned far to close to the valves on the standard set up and will restrict max bhp.
Also the ZETEC normally fires the injectors sequentially, if you change to batch fire your injectors will effectively have about twice the capacity over standard.
Old Feb 10, 2007 | 08:09 AM
JesseT's Avatar
JesseT
Didn't know N/A was an option
What you say about the injector capacity doesn't make much sense. An injector flows what it flows, and when they are maxxed, they are 100% of the time open, sequential or batch.
Keep in mind that the zetecs have big choice of inlet manifolds and even teh old aluminum ones come in two different versions. The 1.8 105hp version will flow much less than the 1.8 130hp version. That's something you have not mentioned in your website.
It's a good website by the way.
Ram:
They really are not, although one design is more common than the others, but that's not the case here as we are talking side fed injectors.
Old Feb 10, 2007 | 09:52 AM
Wardy257's Avatar
Wardy257
Ram:
When fired sequentially an injector has to inject 100% of the fuel requirement in one go. When batch fired the injector fires 50% of the fuel requirement each engine revolution, so twice 50% per engine cycle. So you effectively have double the injector capacity becuase it can have two shots at injecting all the fuel in.
Old Feb 10, 2007 | 10:21 AM
JesseT's Avatar
JesseT
Ram:
You're not making any sense in the last sentence. If a 380cc injector is good for, let's say 60hp per cylinder. It is that for both sequential and batch firing managements. The number of times injected per two revolutions will be different, but the duty-cycle of the injector is all that counts.
Old Feb 10, 2007 | 11:21 AM
Wardy257's Avatar
Wardy257
Some quotes
As rpm increases, the amount of time available to inject the fuel decreases. This is true whether the system is timed to valve opening or batch fired. The batch fired system has the advantage of being able to inject fuel for the entire period of crankshaft rotation whereas the timed system technically only has the time available that the air is flowing in the intake runner. This is determined mainly by the camshaft characteristics. On an average performance cam having 220 degrees of intake duration measured at .050 valve lift, the sequential system has only 61% of the time to inject the fuel as the batch fired system. As such, true, timed, sequential systems must have larger injectors fitted for a given hp.
From Dave Walker
With batch fired injectors some fuel always hangs around in the inlet port waiting for the valve to open. With a sequential system the fuel is only injected during the valve open period and also timed so that none of the fuel follows any air escaping out the exhaust port during the overlap period (all valves open around TDC at the top of the exhaust stroke). That isn’t as simple as it sounds.
With a soft, or standard cam, the valve open period is relatively short so you do not have very long to get the fuel injected. When the fuel demand stretches the injection period past the valve open period you end up with the same result as batch firing: fuel hanging around the inlet port waiting for the valve to open again. This means you need a lot of fuel delivery in a short time period if you want to operate truly sequentially.
You can achieve this with bigger flowing injectors, higher fuel pressure, or a combination of both. ............. In theory you have to match your flow rate to the cam duration, not just the overall fuelling requirement.
The flow rate of the injector is based on it being open all the time so not relevant. The duty cycle will differ depending on whether it is batch fired or not. As 99% of people do not use sequential injection on aftermarket application them most caculations are designed for batch fired systems.
Old Feb 10, 2007 | 02:00 PM
sailorbob's Avatar
sailorbob
Batch and sequentially injected engines produce the more or less same power for the same size injector. I say more or less because you shouldn't run injectors at dutycycles greater than typically 80 - 85% and this is where sequentially injected engines can have the edge over batch fired if the injector rail is too small. This is because you get greater pressure fluctuations that reduce flow on the batch fired system.
Those quotes are misleading because most sequential Ford ecu's start their injection when the inlet valve is closed, so being limited to when the valve is open does not apply. At higher pulsewidths the injectors remain firing until the valve is open.
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
