Bleeding Brakes!!
Mate by reading your last reply you really don't have a clue on how to bleed brakes do you.
Perhaps its worth paying for someone to do them for you, afterall your brakes are kinda important.
well the brake dluid you need obviously
the length of pipe you can use any old bit of pipe (or not use one at all!) the bottle, just use an old cup or summink
I bought a kit from halfords which is just a bottle and a pipe with an anti return valve. Also got 2m of clear plastic pipe and a plastic joiner (near the windscreen wipers, the pipe is actually for the windscreen washer). I can have the bottle in sight while I press the pedal, the anti-return valve means I can walk round to the car when the fluid is clear and close the bleed valve without re-introducing air in the system.
Worked for me purrfect, just need to keep an eye on the fluid level in the engine bay that's all cos you use a bit more of it that way.
frog, ive used one of them before with success... but it wont give a PERFECT bleed like the ol pasioned way will as the 1 way valves aint great...
handy if you not got any mates tho
Originally Posted by zvhturbo
Normally:
1, front drivers side
2, rear passenger side
3, front passenger side
4, rear drivers side.
If you only use the little piece of tubing that comes with the kit, then yeah, chances are the bleed won't be purrfect.
, none of them are interested in helping with me car though
I'm bleeding a S2 i live real close to town so if the worst comes to the worst i'll take it to the garage for them to do but i doubt i'll have to
I thought you half filled a bottle with fluid connect the pipe to the bleed nipple with the pipe in the bottle and pumped the pedal till no more bubbles appear or untill lots of fluid has passed through, plus keep the top off the res and keep topping it up
Yeah, should be alright as long as there is no air left in the plastic pipe at all, otherwise it can make it's way back into the system by the time you've legged it round the car...
