RS Turbo Clear-out
as ive gone zetec im selling off all my rs turbo parts.
i bought 4x new injectors, and only started the car once there after with them so they are still as new, fitted in sandwich plate (wish was shot blasted clean)
these have been kept in the front room cupbaord since, much to my gf moaning about it lol
£80 + postage
Bailey DV26 Dump valve, servicable type, works well.....Offers
i have 2 good condition rs turbo dizzys, both 100% working, both have unbroken plugs and the covers that are inside...
can get pics if required....Offers for each or both.
Kenlow Variable Thermostatic Fan Control that allows you to set the temp your fans cut in.
easy to fit, has varible controller, temp sensor and all wiring.
£30 posted
ive got a 2.5" bore mongoose stainles steel exhaust from a series 2 rs turbo, it has a 4" exit on the back box., outwardly rolled)
no damage and its a solid systm (no flexi joint), the only mark is where a flamer kit was fitted to the side of the tail pipe but its not hat noticable.
Pics can be made avalible if requested and item would need collecting.
its in sepreate peices at the mo, making it easier to transport
£150 ono, must be collected.
as title, wiring loom for a series 2 rs turbo, has been cut in 2 places:
1. halfway up drivers door, would just need splicing back into your loom
2. the wiring to the roof clock, as before would just need splicing back into your loom
come with relays and only the fueling (black) ecu.
came out fo a fully working car, but no longer needed due to change in plans.
££££offers on it, and would prefer collection as it will cost £21 to post, would be willing to have a courier collect if you arrange.
Matt
£80 + postage
£30 posted
Matt
JK12
33
Apr 26, 2021 12:09 PM
