2wd
Old Feb 6, 2007 | 08:15 AM
S1Luke's Avatar
S1Luke
Default 2wd
I have been offered a set of front brake calipers for a cosworth. Only problem is the guys who is selling them doesn't know if they're for a 2wd or 4x4. I require a 4x4 set.
How can I tell??
All help apreciated.
CheeRS
Old Feb 6, 2007 | 08:46 AM
escort mk6's Avatar
escort mk6
The 2wd has the 2 pots on the outside, like the pic:
The 4x4 has 1 bigger one (if they are like the Esc Cos ones, which im pretty sure they are?)
Old Feb 6, 2007 | 11:59 AM
As he above says, just look for the pads if you can see them from side on view they are 4wd as you can see these in the carrier, the back of the pad.
4wd single piston sliding caliper, 2wd ones 4 pots much much better.
Old Feb 6, 2007 | 01:03 PM
S1Luke's Avatar
S1Luke
Thanks Guys
Appreciated
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
arfurski
Sep 26, 2015 10:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
