SQL Server 2K Question
Old Sep 8, 2004 | 10:18 AM
Jim Galbally's Avatar
Jim Galbally
Default SQL Server 2K Question
you never know, sum1 might know
i've got a program which gets data from a SQL source and you can get the data from either a specific table or a specific query within the database
the data i need is all mixed between different tables, so i need to write a query to get all of it out (the easy bit i can do)
but how do i save that query within the SQL database so that i can get this program to use it? i cant find any options in SQL Query Manager, or SQL Administrator
and i dont have any documentaion or manuals etc to refer to, n cant find any help with google
Old Sep 8, 2004 | 10:23 AM
Rene's Avatar
Rene
done loads of work with SQL but have no idea other then to code the actual query to get data from the DB
What program u got ?
Old Sep 8, 2004 | 10:41 AM
JohnnyB's Avatar
JohnnyB
You want a program to use the query you just wrote?
What program?
Old Sep 8, 2004 | 10:58 AM
Jim Galbally
its some labelling program...
just foudna section in the enterprise manager called VIEWS and it could be what im after... but i just saved a view n it didnt appear in my program
here's my view statement:
Code:
CREATE VIEW dbo.Jimtest
AS
SELECT     dbo.StyleColourSizeSellingCodes.Item_Code, dbo.StyleColourSizeSellingCodes.ID, dbo.StyleColourSizeProducts.Style,
                      dbo.StyleColourSizeProducts.Colour, dbo.StyleColourSizeProducts.SizeX
FROM         dbo.StyleColourSizeProducts INNER JOIN
                      dbo.StyleColourSizeSellingCodes ON dbo.StyleColourSizeProducts.ID = dbo.StyleColourSizeSellingCodes.Item_Code
here's the program 9that comes with NO help file
Old Sep 8, 2004 | 11:05 AM
RANJ's Avatar
RANJ
jim have u actualy thought of posting this on a related forum, as u will get more positive help
Old Sep 8, 2004 | 11:16 AM
Jim Galbally
ranj, considered it...
...then couldnt be arsed to register on one
Old Sep 8, 2004 | 11:17 AM
RANJ's Avatar
RANJ
Old Sep 8, 2004 | 11:41 AM
Jim Galbally
ok im gonna try some other ODBC drivers to see if they give me any more settings... got MDAC 2.8 downloaing at the moment... if that dont work ill try a 3rd party driver
Old Sep 8, 2004 | 12:39 PM
AndyHey's Avatar
AndyHey
you could do its as stored procedure also which is exactly as it sounds - a bit of sql stored to be run anytime.
Code:
CREATE Procedure
                   yourspname
AS
you can then just call the sp from your app
Old Sep 8, 2004 | 12:55 PM
Jim Galbally
cant call procedures from the app
its basically just using an ODBC plugin for its DB connectivity
Old Sep 8, 2004 | 02:10 PM
Jim Galbally
THIS IS DOING MY FUCKING HEAD IN
ok quick fix, how can i create a new table in the database containing the data from that query above, then i can just query the table directly
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
