Vems in Escort Rs Turbo.
Hello! I write from Spain.
I have a Escort Rs Turbo S2, 1.8 zetec bottom end and 1.6 CVH head.
The inlet manifold and Ecu from Fiesta Turbo, OFAB.
I would like to know, all necesary, one to have a trustworthy and powerful engine. Fuel injectors, rising fuel rate...etc
I do tarmac rally in Spain.
Phat talk me, talk with APT members, Gary, Christian...
I hope to be able to follow your advice.
Thanks.
Thanks.
Hello, what would you like to know exactly? The 1.8 Zetec isn't very strong, you would be better using the 1600 with some steel conrods for a very strong engine. The standard fiesta fuel pressure regulator from a fiesta is fine. You must not use a rising rate regulator.
Dr. Ickxs
Sep 15, 2015 10:15 PM
