Turbo > Exhaust Downpipe seal
Chaps, I seem to be unable to seal the exhaust downpipe where it meets the turbo. I've tried it in all manner of positions but it just wont seal. It's a brand new mongoose exhaust and the flange seems quite a bit wider than the raised circular part on the turbo.
Should there be a gasket on there or should the join be purely metal-metal????
HELP
Lee
HELP
Lee
Originally Posted by Alex_86
u could take on some exhaust sealing creamy thing dont no what is called in english
TRY de rusting the seat with wire brush in drill, as it may have small pieces of carbon stuck on there and check flange on new exhaust has not been distorted.
Check also that the seam is not causing this on new flange file it off if necessary.
The other thing, as the flange is offset at an angle, the clamp part (That the bolts go through) doesn't sit at the same angle.
I'm confused and I think I need to see some pics, anyone got any to hand?
Matt Baxter
Sep 16, 2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
