Audio Problems
Old Feb 4, 2007 | 04:18 PM
Shandy-Ade's Avatar
Shandy-Ade
Default Audio Problems
I have a 640watt amp in my car and i've had it for about a year, just recently the speakers have been crackling, then all of a sudden i had no sound, i replaced the amp with a JBL 600 watt, wired it all in using me existing wiring kit, and nothing! checked the fuse from the main 12v from battery and it had melted. was a 10amp, i replaced it with a 10amp fuse and the speakers were again crackling, i then put in a 20amp fuse and it was fine, i then thought a 20amp was to much, so put a 15amp in, but now when i turn the stereo up the amp cuts out, then couple of mins later it will kick back in.
I've tried using a different earth, but the same happens.
Any ideas?
Thanks
Old Feb 4, 2007 | 05:15 PM
Make sure you have no speaker wires touching each other or earth.
Waht size fuse does amp manufacturer say to use ?
Old Feb 4, 2007 | 05:19 PM
Shandy-Ade's Avatar
Shandy-Ade
I've made sure the speaker wires aren't touching and the earth is some distance away so it isn't touching the earth either, not sure what the manufacturer says as i haven't got a manual for the amp, and the wiring kit was bought from halfords when i fitted my first amp over a year ago.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
