no power or power only at 18 deg
Old Feb 3, 2007 | 04:21 PM
////ANTHONY's Avatar
////ANTHONY
Default no power or power only at 18 deg
set the timming at 12, 14, 16, but only get power at 18 ish deg advance but engine starts pinking
anyone know whats going on?
i running 1 bar boost and have these bossch plugs but will get some motorcraft ones soon
Old Feb 3, 2007 | 04:31 PM
project rs's Avatar
project rs
when you say only getting power at 18 degrees what power you on about? peak power or you mean it's running like a bag off shit unless you set it at 18 degrees. has anyone been at the cam belt end of the cam shaft any more info on your spec might help diagnose the problem
Old Feb 3, 2007 | 05:05 PM
SafeChav's Avatar
SafeChav
What engine is it?
Old Feb 3, 2007 | 06:52 PM
////ANTHONY
yup runs like shite as soon as it starts to boost, feels like you have sudenly took your foot off the gas,
its had a new timming belt fitted and both crank and cam pullys are spot on,
engine is a 1.6 s2 engine, its a donor engine and had been reconditioned by the previous owner but number 4 valves do sound a little knocky,
i had to change the oil pump gasket a year ago and i had a look up at the pistons and they look new, clean silver colour,
the breakers says that the engine had bigger valves fitted,
it has blue ford racing leads
full stainless steal zaust
newist turbotecknics turbo
drilled air box with cleaned panel filter(green one)
standard intercooler with boost pipes diverted away fro hot zaust
boost air temp guage that dosnt realy go over 40c on boost
knock sensor mounted off the engine and hole blocked with old knock sensor
all boost pipes are tight 99% sure theres no air leaks
would an adjustable cam wheel help anything?
im using v power petrol
Old Feb 3, 2007 | 07:36 PM
SafeChav's Avatar
SafeChav
Get it to a tuner mate, something doesnt sound right and its a matter of time before the head gasket goes.
P.S you didn't buy my bottom end off eBay a while back then?
Old Feb 3, 2007 | 09:07 PM
////ANTHONY
yes ill get it on the rollers soon, is the dyno pack any good at pj motorsport in wolverhampton? but pjs seen so expensive , any other good tuners near wolverhampton
na didnt buy ya bottom ent off you, how much did you get for it
Old Feb 3, 2007 | 10:50 PM
SafeChav's Avatar
SafeChav
Sold it for £450 i think it was, new pistons, 0.5mm rebore etc
Old Feb 3, 2007 | 11:03 PM
Rick's Avatar
Rick
This is common on ESCII
I can sort if for u if u can get to cheshire.
BTW - i have run plenty of cars at 20BTDC.
I rarely use a timing light to setup RST's now - as i dont know the content of the ignition map.
Old Feb 4, 2007 | 09:47 AM
DazC's Avatar
DazC
If you're in wolverhampton. The best thing to do would be to take a trip over to norris motor sport. Probably the best place to go.
Old Feb 4, 2007 | 09:52 AM
////ANTHONY
20btdc is that crank to cam timing? so thats like putting the timming belt 1 tooth out? advance or retard? how much can i get an adgustable cam pully wheel for?
ive had this stinking van for 7 years now, it was great for the first 30 mins taking it home then a valve spring broke, since then ive changed everything and i took it to aldons it was doing 120 bhp at the wheels at 1 bar boost,he called me and said whats up with it ill not go there again, but he did say it was running rich top end but that was bcos i had a leak on one of the pipes but ive fixed that after 7 years of no power,
cheshire? how fars that from wolverhampton? thanks for your help guys
Old Feb 4, 2007 | 05:16 PM
Rick's Avatar
Rick
are we talking about ignition or valve timing?
Old Feb 4, 2007 | 05:21 PM
Fiecos Dan's Avatar
Fiecos Dan
if its only started to run bad after the belt change, then its got to be incorrect cam timing.
Old Feb 4, 2007 | 09:21 PM
////ANTHONY
no no, its the same after chainging the belt, crank to cam timming is spot on,
im sure that my problem is that im over fueling on boost, i realy need to get it set up on the rollers, or maybe get an air to fuel gage
Old Feb 5, 2007 | 01:22 PM
Dragsteer's Avatar
Dragsteer
how can I know if I have overfuel under boost? isnt erst fuel system self adjusting??
Old Feb 5, 2007 | 04:45 PM
SafeChav's Avatar
SafeChav
im sure its been said before and i'll say it again.
TAKE IT FOR A ROLLING ROAD SET UP or spend £250+ on a PROPER AFR gauge
Old Feb 5, 2007 | 05:05 PM
davidnormanuk's Avatar
davidnormanuk
I agree with the rolling road setup. You don't want to be melting the engine. I've been told it only takes as little as 30 seconds to do serious damage.
Old Feb 5, 2007 | 05:54 PM
Fiecos Dan's Avatar
Fiecos Dan
It will have to be mega rich/lean to have no power,
could be a engine/ management fault or even a zorst block.
best take it to a tuner.
Old Feb 5, 2007 | 05:58 PM
Dragsteer's Avatar
Dragsteer
but for having AFR gauge I must have lambda
Old Feb 5, 2007 | 05:59 PM
Fiecos Dan's Avatar
Fiecos Dan
Yes.
Old Feb 5, 2007 | 06:06 PM
SafeChav's Avatar
SafeChav
Then buy a wideband lambda and fit it.....?!
Old Feb 5, 2007 | 08:31 PM
Dragsteer's Avatar
Dragsteer
But this cost :-( how much ? maybe 100 pounds ? if more
Old Feb 5, 2007 | 10:11 PM
////ANTHONY
anyone got a list of all the repatable dynos near wolverhampton not aldons
how much will they charge to set it up for me? ill ring norris this week,
but i need to get a new cam set first before i get it on the rollers, its abit knoky at 2krpm,
i think pjs wanted £150 for an afr gauge fitted 2 years ago
Old Feb 6, 2007 | 02:08 PM
SafeChav's Avatar
SafeChav
Well its either spend £100 on that or blow your engine up and pay for the rebuild.
Im not being funny but if your a bit tight with your money may i suggest you don't modify your car..........................?
You can't have your cake AND eat is as the saying goes
Old Feb 6, 2007 | 03:11 PM
Dragsteer's Avatar
Dragsteer
yes I konw but I think fuel sistem on RST is self adjustable, that means that sistem self adjusting amount of fuel on all rpm range (?)
Old Feb 6, 2007 | 03:23 PM
SafeChav's Avatar
SafeChav
Only to a certain extent like everything.............
Old Feb 6, 2007 | 05:49 PM
Fiecos Dan's Avatar
Fiecos Dan
The cheapest wideband AFR meter i've seen is £170, to buy, then add maybe £75-150 to fit.
Sounds like PJ's offered you a narrowband AFR, this wont be anygood for tuning any cars.
A wideband is what you need.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
