Cossie central locking
Old Feb 3, 2007 | 09:26 AM
timster's Avatar
timster
Default Cossie central locking
Hi i'm having problems with my central locking,it works fine on the key but when trying to use my alarm key fob it just locks then unlocks straight away.Tried using the passenger side lock on the key and it gives the same symtoms as the key fob,my mate reckons its the opposite side thats the problem(drivers door)has anyone else had the same trouble?
Old Feb 4, 2007 | 07:00 AM
It usually is the other side as this is used less and tends to seize up more as a result.
It souinds as though it is not acheiving FULL TRAVEL on one of the lock mechanisms, so it thinks it should still be locked and sends a locked signal.
You need to take of the door panle etc and unseize the locks and or rods, the oe lock motor has not got suffecient pull in short space of time to overcome stuck bit most likely just some coppaslip on lock components will cure it, I would go for passenger side first.
Old Feb 4, 2007 | 04:25 PM
timster's Avatar
timster
Thanks for the reply,I took off the passenger side door card and disconnected the latch that works the door lock but still get the same result
Old Feb 4, 2007 | 05:13 PM
Do same to drivers one, then disconnect each in turn(wires) to see which is naughty one.
Old Feb 4, 2007 | 05:29 PM
KSA-Cossie's Avatar
KSA-Cossie
Sorry to hijack your thread m8 , my c/l plays up now and again too it will lock ok on the passenger side but locks and unlocks on the drivers side which side will be the naughty one ?
Old Feb 4, 2007 | 05:52 PM
LeviA's Avatar
LeviA
Isn't this the common Ford problem of repeating locking? Sounds like a cow mooing when it lock and unlocks. I forgotten how I fixed it now though
Old Feb 4, 2007 | 09:43 PM
timster's Avatar
timster
I'll try that tomorrow thanks,also my brake light check is staying on inside the car even though all the lights work perfect.Its got all the right bulbs in the right places any ideas?
Old Feb 5, 2007 | 07:37 AM
Are your brake lights coming on ?, does it have a broken wire/switch ?
Old Feb 5, 2007 | 09:35 AM
timster's Avatar
timster
Yeah everything works fine but not according to the computer!
Old Feb 6, 2007 | 12:21 PM
Buggered if I know then, small bit of black paint on symbol ?, to block it out.
The warning light bits I think use REED RELAYS to detect current flow but not too clued up on electronics, probably going to be a new bit costing millions, if you can get it!!
Old Feb 6, 2007 | 12:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Anyone help ?
Old Feb 6, 2007 | 02:41 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Watch the levers when you lock the door...
My old Sierra LX's did this, and it's usually the passenger front that appears to sieze. Operating the lever (opening the door from the inside ) is usually enought to sort it.
Also, don't rule out the boot lid's lock - if it's slightly 'out' it won't lock and will re-cycle the system. Doors that aren't shut properly or misaligned can also induce this problem.
Old Feb 6, 2007 | 02:43 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I had this the other day!
reseat the cluster multiplug connectors, and reseat all the bulbs.
The system's designed to be able to tell the difference between a short and an open circuit.
Old Feb 6, 2007 | 09:24 PM
timster's Avatar
timster
Thanks for that,if the reseting of multiplugs and bulbs doesn't work i'll go down the black paint route!
Old Feb 7, 2007 | 10:21 AM
timster's Avatar
timster
Tried that reseating connector and bulbs but no joy,just out of curiosity,indicator single element,next one(moving towards centre of car)double element,next one single fog light,inside one reverse light single element yeah?
Old Feb 7, 2007 | 12:23 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Indicator (outer most) is single.
Next inwards is the sidelight/foglight - twin filament.
Next is the reverse light - single.
Next (inner most) is the brake light - single filament.
Old Feb 7, 2007 | 09:15 PM
timster's Avatar
timster
cheers fella
gcfcos
59
Oct 6, 2015 05:04 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
rsguy
44
Sep 29, 2015 03:29 PM
