M3 Electric Mirrors Mk4 Cabby
Old Feb 2, 2007 | 05:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default M3 Electric Mirrors Mk4 Cabby
Just went to fit a pair of M3 mirrors that i got from Ebay to my S2 Cabby and noticed that the pin config is different, standard mirrors have 5 pins and the M3 has only 4 pins!
Also a different connector, but thats no bother i'll just chop it off, but does anyone know how to wire these up or maybe a diagram/explanation of how the standard mirrors are wired?
M3 ones are easy there is 2 wires for up/down and 2 wires for left/right, i'm guessing that the polarity is reversed depending on which way you move the mirror joystick.
Thanks!
Karlos.
Old Feb 2, 2007 | 06:06 PM
SafeChav's Avatar
SafeChav
Thats the same way the MK4 mirrors work they have a motor for each direction.
Have a look in the haynes its got a wiring diagram in there.
Old Feb 2, 2007 | 06:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So whats the 5th wire for?
Old Feb 2, 2007 | 07:07 PM
SafeChav's Avatar
SafeChav
The M3 mirrors probably aren't heated, where as your existing ones are.
And i think the heated mirrors are really useful in this cold weather.....
Old Feb 5, 2007 | 04:37 PM
SafeChav's Avatar
SafeChav
Old Feb 5, 2007 | 08:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
yeah your right they were for the heated mirrors, the actual motors only use 3 out of the 5 wires!
Side to side is working now but not up and down, proper confusing!
Old Feb 6, 2007 | 02:05 PM
SafeChav's Avatar
SafeChav
As i said it takes 4 wires to get all directions..............
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
