oil pressure sensor fitting (3 door) ????
I've got to fit the oil pressure sensor for my defis.
do you need an adaptor or can you just screw it straight in?
in fact come to think of it where is the existing switch?
You can just screw it in but you will lose the dashboard oil light.So best to get an adaptor for it.It located under the inlet manifold at the back next to the dipstick.The oil feed for the turbo is also located here so look out for the braided pipe.
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
cossie before!!!!
