Upgrading to EFI
Hi guys, I'm making some research to upgrade my RST to EFI but I'm still a bit confused about it. Omex offered me an upgrade package (excluding the inlet manifold) obviously. This is the list of parts:
ECU
Programming kit
Coolant temp sensor
Air temp sensor
Adaptors for ATS and CTS
WIRING OPTIONS
Ready built harness
or
Semi assembled harness
Aux wire pack
2 pin m/t connector
3 pin ford connector
3 pin m/t connector
OPTIONAL PARTS
Injectors
Trigger wheel
Crank position sensor
MAP SENSORS
2.5bar (max 1.5bar boost)
or
3bar (max 2bar boost)
Is this all I need for the upgrade plus the inlet manifold? Do I need anything else from the Fiesta, like wiring loom, ECU, etc? Do you suggest OMEX or MegaSquirt? Thanks
ECU
Programming kit
Coolant temp sensor
Air temp sensor
WIRING OPTIONS
Ready built harness
or
Aux wire pack
2 pin m/t connector
3 pin m/t connector
OPTIONAL PARTS
Injectors
Trigger wheel
MAP SENSORS
or
You will need some sort of trigger wheel, either a fiesta flywheel & cps, a 1.8 sierra front pulley and sensor or an aftermarket trigger wheel and sensor. Also the fuel lines will have to be changed to meet the fiesta manifold/fuel rail.
Lots of information on EFI convertions on here...
http://www.oddkiddcreations.co.uk/forum/
Ł1250 with all the optional parts included, 3 bar map sensor and ready built harness. The injectors are included as well and cost Ł288 and they use something very similar to Fiesta's beige injectors, if I'm not mistaken by Weber instead of Bosch. They also have more powerful injectors (pico-fitment) than the Fiesta's but a bit shorter in length, for the same price, which they told me I can use by shortening the distance between the fuel rail and the inlet manifold.
I'm not from the UK. What injectors do you normally use there guys? I'm aiming for high power and I want to do things right the first time. Do you think that Omex is better than Cossie conversion. And one final question... where can I source (ONLINE) a complete Fiesta Inlet manifold if possible exc. injectors? Thanks
Hi guys, I found this one here on ebay. What do you think? How much do they normally go for?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true
Omex do make shit hot ECU's but for me personally Ł1250 is a LOT of money. If you can afford it then you can't go far wrong.
That eBay item isn't a FRST one, it has the wrong IAT sensor
And regarding that inlet manifold... you're saying it won't work on an EFi conversion?
Sorry if I'm asking too many stupid questions guys but I need to do my homework well before spending all that money. Thanks for your help
lol i never said i recommend the cossie conversion? Omex ECU's are good......if you can afford to spend the money get the Omex!!
The inlet will work but it has the wrong Inlet Air Temperature senders, the senders are expensive, and they require a reducer which is no longer available from ford.
keep your eye out a proper FRST one will come up!
Thanks SafeChav and all the others for your help
Btw, I might be visiting England next year and I'm gonna stay at Bedfordsire. Do you know if there's any place nearby that might be of interest to a Ford and motorsport enthusiast?
