flow rate of dark greens
Old Jan 31, 2007 | 08:25 PM
tommyt's Avatar
tommyt
Default flow rate of dark greens
Anybody tell me the flow rate of 803 dark greens
also whats the voltege ment to be at the iscv on a frst
thanks
Old Feb 1, 2007 | 06:22 AM
Ask boschman for flow rate.
as for ISCV voltage, it is a DIGITAL SIGNAL, therefore you CANNOT measure it with a regular digi metre.
As with 99.99% of ECM(ECU) refernce signals are 5 volts, but as I said are in this case a DIGITAL SIGNAL, not AC like some "knowledgeable" people believe.
Old Feb 1, 2007 | 01:12 PM
SafeChav's Avatar
SafeChav
The ISCV's are PWM aren't they
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
