Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
COSSIE ENGINE INTO A MRK 2 ESCORT
Old Jan 31, 2007 | 12:40 PM
giz1888's Avatar
giz1888
Default COSSIE ENGINE INTO A MRK 2 ESCORT
How hard is it to put a 2wd cossie engine into a mrk 2 escort is it straght forward or does the engine bay or anything else need modified all help gratefull cheers
Old Jan 31, 2007 | 02:52 PM
Markb_s1's Avatar
Markb_s1
how long is a piece of string mate?
It'll be much cheaper and easier to get one already done than converting one yourself i reckon.
Old Jan 31, 2007 | 03:58 PM
John Doe's Avatar
John Doe
https://passionford.com/forum/viewtopic.php?t=248859
Old Feb 1, 2007 | 03:05 PM
BigDave's Avatar
BigDave
The actual engine will go in dead easy. Its basically a pinto at the bottom anyway. You will probably have to bash the lip of the bulhead back to clear the cam cover, but tother than that it fits.
One thing to watch though, is the sump. But you would most likely be using a WCXM anyway I take it??
Oh yeah, if using a turbo there are other point to be mindful of such as turbo clearance for 4x4 mainfold, intercooler location, buring of your clutch cable!
But the engine itself goes in dead easy.
CheeRS
Dave...
Old Feb 8, 2007 | 03:58 PM
WRCjames's Avatar
WRCjames
You'll have to do away with the brake servo aswell as the turbo sits there. Retro Ford mag are doing a technical feature on it all next month.
Vincereese
Jun 1, 2023 09:14 AM
y4n
Aug 17, 2015 12:12 PM
Vincereese
Aug 16, 2015 06:38 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
Old ford
Jul 31, 2015 06:50 AM
