Anyone know much about BMW E36 328 Sports
Old Jan 31, 2007 | 09:24 AM
-J-'s Avatar
-J-
Default Anyone know much about BMW E36 328 Sports
Going to look at one in Wolverhampton with a mate on Saturday, Any "Known issues" or anything specific we should be looking for?
Old Jan 31, 2007 | 09:26 AM
xr2i-carl's Avatar
xr2i-carl
people selling a 'non sports' as a sports. Think it should be on the logbook either that or can check by ringing BMW directly
Old Jan 31, 2007 | 09:28 AM
Mike1's Avatar
Mike1
Default Re: Anyone know much about BMW E36 328 Sports
Lots of things to watch out for
Rear brake pipes as they go over fuel tank rust
Rear trailing arm bushes will give unwanted rear wheel steer
Check to see if it's had a recall for Nicasil block and Steering coupling.
Vibration from front under braking can be worn front wishbone bushes and/or warped discs
What year is it out of interest?
Only early Sports had a LSD - later ones got traction control
Old Jan 31, 2007 | 09:48 AM
-J-'s Avatar
-J-
Its a 1996 N Reg, Listed as having LSD and No Traction Control!
Sounds like there is plenty to look for!
Will the Recall be listed in service manual or somewhere? Its apparently got a FBMWSH so i should imagin its all upto date with recalls etc.
Old Jan 31, 2007 | 09:54 AM
Mike1's Avatar
Mike1
It's like all 10 year old cars - there's plenty to look for - all the usual old car rules apply
If it's been serviced all it's life at BMW they will be able to tell you if it's had a new short engine and steering recall done if you ring the head office with chassis number. I can't remember the number tbh
Old Jan 31, 2007 | 09:56 AM
xr2i-carl's Avatar
xr2i-carl
think you can ring any dealer to find out cant you..?
Old Jan 31, 2007 | 10:06 AM
Mike1's Avatar
Mike1
Give it a whirl and find out?
Old Jan 31, 2007 | 10:09 AM
xr2i-carl's Avatar
xr2i-carl
i rang up my local dealer when i needed to find out if mine had lsd
Old Jan 31, 2007 | 10:11 AM
Mitchevo's Avatar
Mitchevo
If it has full BMWSH phone the dealer with the reg number/chassis n umber and they will tell you if it has been recalled for a new block due to
Nicasil issues. I think the problem was sorted late 1998 if my memory serves me right.
Old Jan 31, 2007 | 10:12 AM
Mike1's Avatar
Mike1
It was about April/May 98 build cars onwards
Old Jan 31, 2007 | 10:13 AM
IAIN ABZ's Avatar
IAIN ABZ
Yeah i think they replaced all the alloy blocked cars with iron blocks as part of a recall ????
Old Jan 31, 2007 | 10:50 AM
-J-'s Avatar
-J-
Cheers for all your help good place for me to start!
Old Jan 31, 2007 | 10:54 AM
Mitchevo's Avatar
Mitchevo
Also check for rust on rear arches, the panel below the rear number plate and the bottoms of the front wings, if you get a good one you will really enjoy it!!!!
Old Jan 31, 2007 | 11:01 AM
-J-'s Avatar
-J-
I Already know its got a 5p size patch of rust on the numberplate pannel but not letting that put me off as its dirt cheap car....
Will give it the once over on Saturday and see whats what
Old Jan 31, 2007 | 11:06 AM
AlexF's Avatar
AlexF
No they replaced the blocks with the same blocks!!
Some even suffered the exact same problem!!
Alex
Old Jan 31, 2007 | 04:41 PM
Mike1's Avatar
Mike1
Alex
Very true Alex, before BMW got to the root of the problem they replaced like with like so some cars went through the cycle a couple or three times.
It was only whe they realised the problem lay with sulphur in fuel attacking Nicasil liners that they used the steel-linered blocks
Old Jan 31, 2007 | 05:48 PM
xr2i-carl's Avatar
xr2i-carl
Alex
mike do you work for bm??
Old Jan 31, 2007 | 09:02 PM
Mike1's Avatar
Mike1
No but I think Alex does though
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
roomey
Sep 19, 2015 08:40 AM
