drive shaft
Old Jan 30, 2007 | 09:00 PM
rs2alkis's Avatar
rs2alkis
Default drive shaft
hi im looking for a passenger side drive shaft for a mk4 s2 rsturbo.....ive found one on ebay but its for a mk3 xr3....could i fit this one on my car?
Old Jan 30, 2007 | 09:29 PM
SafeChav's Avatar
SafeChav
Does your car still have the ABS?
Old Jan 31, 2007 | 04:51 PM
MarkN's Avatar
MarkN
If it's from an original carb XR3 with a four speed then it is probably a different length to the one you have. I wouldn't bid on it unless you can check the exact measurements
Old Jan 31, 2007 | 07:09 PM
SafeChav's Avatar
SafeChav
Its unlikely to fit anyway as all S2's left the factory with ABS.
Old Jan 31, 2007 | 11:38 PM
Grandad racer's Avatar
Grandad racer
id keep away from mk3 parts, but you can fit eny mk4 drive shafts. my s2 turbo is running a dieasle gear box and xr3i abs drive shafts, and the abs has been taken off the turbo.
Old Jan 31, 2007 | 11:41 PM
SafeChav's Avatar
SafeChav
not ANY mk4 shafts, they have to have ABS inner CV joints and its actually quite a rarity to find ABS cars i find!
Old Feb 1, 2007 | 09:20 AM
rs2alkis's Avatar
rs2alkis
Default drive shaft
thanks alot guys
Old Feb 1, 2007 | 11:42 PM
Grandad racer
problem sorted!!! look out for xr3i abs shafts lots ov those around, wicked!! was in llandudno last week and went to local scrap yard. they had 3 xr3i cars in, and 1 was a cabs.
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Bransby
Sep 11, 2015 09:12 PM
rsstav
Sep 7, 2015 04:43 AM
