Turbo water feed pipe crack..
Old Jan 30, 2007 | 07:37 PM
ram's Avatar
ram
Has a large member
Default Turbo water feed pipe crack..
found a crack on the elbow of the metal water feed pipe for the turbo..
i thought instead of buying a new pipe.. id hacksaw the pipe at the crack and rejoin it using some samco silicone hose i have of the same size.
my question is...will the silicone hose withstand the temperature the turbo will produce?
cheers in advance
Old Jan 30, 2007 | 08:31 PM
Tor @ Racefix Motorsport's Avatar
You`d be better off getting your pipe brazed, in my experience they usually crack where its welded to the banjo union.
Shouldnt be a problem for an experienced welder to do this.
Old Jan 30, 2007 | 09:17 PM
ram's Avatar
ram
Has a large member
yeh id like to get it welded but the whole point i wanna repair with a hose is cuz i can do this at home and just put the pipe back on. instead of taking it somewhere to get welded or buy a new one.
cheers for the advice though
Old Jan 30, 2007 | 09:30 PM
SafeChav's Avatar
SafeChav
Should be fine........cars like R5 turbos have rubber hoses right to the core.
Go for it
Old Jan 30, 2007 | 09:54 PM
ram's Avatar
ram
Has a large member
SafeChav helpful as usual mate
Old Feb 1, 2007 | 12:55 AM
rst_cabby's Avatar
rst_cabby
Give it a go as a new pipe is £50 from fords - if it doesn't work then get it welded - it would be the cheaper option .........
Old Feb 1, 2007 | 06:18 AM
You need to find out why it cracked first.
Silicone is a very high temp material so will be fine, as this is actually what it was designed for high temp situations.
Old Feb 1, 2007 | 01:00 PM
SafeChav's Avatar
SafeChav
The metal pipe cracked.........not the silicon one?
Old Feb 1, 2007 | 01:18 PM
ram's Avatar
ram
Has a large member
yeh it was the elbow of the metal pipe that had a hairline crack in it..
see https://passionford.com/forum/viewtopic.php?t=249881
and it may enlighten you all on what my engine is doing,
cheers.
Old Feb 1, 2007 | 03:37 PM
JamboRS's Avatar
JamboRS
focus rs 1672
same thing happened to my water feed,i just slid a bit of old hose over it and hose clips on either side if split
Old Feb 1, 2007 | 06:18 PM
I know it's the metal that cracked, just put a silicone over the good uncracked bit.
Old Feb 1, 2007 | 06:44 PM
ram's Avatar
ram
Has a large member
cheers guys.
already done it yesterday and worked fine.
this posts dead, same as my car currently
Oct 9, 2015 07:38 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
