Lowering focus
Old Jan 30, 2007 | 06:39 PM
bick888's Avatar
bick888
Default Lowering focus
Is it true that lowering the rear of the focus is bit of an arse??
cheerz
jake
Old Jan 30, 2007 | 08:08 PM
FRS 3409's Avatar
FRS 3409
nope all a load of codswallop, absolute piece of cake! do it in about 45 mins easily.
Old Jan 30, 2007 | 10:07 PM
bick888's Avatar
bick888
cheerz mate!
Do you fink theres anypoint in gettin uprated shocks when i lower the car?? are the standard ones good enough? its nt goin to be a race car, but i just want it to handle and sit a bit better!! also, how much do i lower it?
Old Jan 31, 2007 | 12:41 AM
FRS 3409's Avatar
FRS 3409
depends how low you are planning on going and what condition they are in. any lower than 35mm and you will start to notice that big bumps in the road tend to make the shocks bottom out due to lack of travel. 40mm - 50mm definatly uprated shocks and any lower coilovers are the way forward.
ian
Old Jan 31, 2007 | 12:41 PM
watson's Avatar
watson
Mine is lowerd 50mm and never had my shocks bottom out.
Coilovers would be the thing to do if you have the money but i picked my springs up for Ł80 and dropped it 50mm was easy to fit did the whole car in about hour and half.
Old Jan 31, 2007 | 05:21 PM
bick888's Avatar
bick888
How does it handle?? isit propper stiff? thats how i want it to be! also does it look good lowered at 50mm?
Old Feb 1, 2007 | 09:06 AM
watson's Avatar
watson
Yeah it handles very well as it is so stiff.
as for does it look good...you tell me
Old Feb 1, 2007 | 09:47 PM
bick888's Avatar
bick888
looks wicked fella!!!
Is it really really bumpy? or just rite? or what?
Old Feb 2, 2007 | 09:01 AM
watson's Avatar
watson
I think its just right, not to soft and not to bumpy, what springs are you going for?
Old Feb 2, 2007 | 09:33 AM
RichieST's Avatar
RichieST
can be a bitch to do, unless your focus is less than a couple of years old then all the nuts will have siezed solid.
Best thing to do is to put the spring clamps up through the hole in the lower arm, then inside the spring, as there will be no space to tighten the clamps up if you put them outside
Old Feb 2, 2007 | 02:36 PM
watson's Avatar
watson
Mine car is a 1999 model and it all came off ok with a bit of WD40 and a strong arm
But your right with the clamps can be a pain if you dont do it on the inside or have small spring clamps
155lee
Sep 6, 2016 11:10 AM
rogerxr3i
Sep 13, 2015 06:56 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
