One for the Electronics people.....
Old Jan 30, 2007 | 03:56 PM
boXXer's Avatar
boXXer
GASH!
Default One for the Electronics people.....
Hello. If i wanted to wire a couple of small high speed fans into my car, how would i go about doing this?
I wanted to put a switch in the car, but im not sure what other bits i need, apart from wire.
Can i just run a postive from the battery, into the switch, then from the switch (with an inline fuse) to the fans? then run the negative to the body of the car?
as you can tell, im total bollox with electrics, so some info would be good.
Mike
Old Jan 30, 2007 | 04:22 PM
Series1Dry's Avatar
Series1Dry
This would work although i would put the fuse in before it got to the switch not after
Old Jan 30, 2007 | 04:26 PM
Moonie's Avatar
Moonie
The current draw of the fans would be too great to just run from a switch, you would end up melting the switch. You need to install a relay that can cope with the current draw of the two fans and control the relay from the switch.
Old Jan 30, 2007 | 05:17 PM
boXXer's Avatar
boXXer
GASH!
well, im looking at a max of 5 amps, so cant i just get a switch that will take that?
Old Jan 30, 2007 | 05:31 PM
St3V3_C's Avatar
St3V3_C
If you know the current of the fans, and can get a switch that says more, then that will be OK. EXCEPT - fuse must be right next to the battery, and deffo before the wire goes through the bulkhead.
Old Jan 30, 2007 | 05:49 PM
Moonie's Avatar
Moonie
Persumed you would be drawing more than 5A
Have a look on here for any bits....
http://www.vehicle-wiring-products.c...page/home.html
Old Jan 31, 2007 | 09:06 AM
boXXer's Avatar
boXXer
GASH!
nah, only 5 amps. So would it be ok run a wire straight from the battery, into the car with an inline fuse, then the switch, then into both fans?
Old Jan 31, 2007 | 09:12 AM
lead_foot's Avatar
lead_foot
is awesome
http://www.vehicle-wiring-products.c...ys/relays.html
R30BT? So you run the fans in parallel?
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
cossie brad
Sep 29, 2015 02:38 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
Roosie
27
Aug 19, 2015 12:16 AM
