Mk2 Orion turbo.....
Heres ma motor....
Just finished turbo'd it the day, completey standard apart from full stainless and filter...well chuffed as first turbo conversion i have done.
Looks abit ruff under the bonnet but wanted to just get running then will start tydyin her up!!
It running very low boost at mo....so i dont blow it up lol!!
Comments welcome!
Comments welcome!
not exactly sure tbh, it's leaking from the bulk head aswel around the battery tray, and on the other side near the wiper motor i think.
but the back jus seam's to be a mistory
was leaking from the boot, but we took the seal off and put sealent around it and put it back on, and moved the boot about abit, so all the line's wer equal, and no daylight gettin thro, that does'nt seam to be leaking anymore, but there's still abit of water gettin in the back where the back seat is
jus cant seam to find where it's gettin in
Check around the sunroof area to mate...
The battery tray and fuse box area is bad on all mk4 escort front ends due to the small rubber stopper on the lip on each wing, where the bonnet rests...this stops the water running down the lip...instead it falls of and rest in batt tray and under fuse box!!
Cut a small bit out each like a wee tunnel so water can travel down rain gutter!!!
Prob solved lol
Prob solved lol
Cheers folks....
As for the 'chav' valve i like it so iam keeping it..lol, although its my first turbo so thinking the novelty will wear off and i need to get a crossover pipe without that take off as i aint got a plug for it the now!
Originally Posted by COSSIE CAL
Originally Posted by sidewayz
get rid of that chav vlave
chav valve?e.g dump valve?my version hasnt i think his has
Get it off though mate, will chatter its little tits off
Originally Posted by beemerbazza
looks good mate, will you be bringing it along to the meet next month in Dundee..?
I will take it off, just when i get a crossover pipe without the take off or a plug for it!! heard alot about the famous Efi chatter!!!!
going back to your leaky boot i had the same problem, it aparantly runs down the gap between the boot and qaurter and in through the lights, i just sealed the back lights with silicone n never had a drop since, tasty mota by the way
Kiran1600E
11
Oct 2, 2015 11:35 AM
