Rubber Trim Bufty Question
Old Jan 30, 2007 | 08:55 AM
Ryan's Avatar
Ryan
Default Rubber Trim Bufty Question
What does everyone use on there dool seals and window seal to make them look ¨as new¨, i've just tried the autoglym stuff, and it seems to give a bit too much of a shiney finish.
want the matt/satin finish u get when there new.
Bufty alert
cheers
Old Jan 30, 2007 | 09:01 AM
MWF's Avatar
MWF
I use Megs Trim Detailer which is on this page in the top left
http://www.meguiars.co.uk/cgi-bin/ca...at=ENT_OTHER#2
It's designed so you have to keep applying layers to get a shine so it might work out better for your seals.
Old Jan 30, 2007 | 09:02 AM
MWF's Avatar
MWF
Also when you apply anything like that you do need to rub it in immediately to stop it shining, like the tyre cleaning stuff.
Old Jan 30, 2007 | 09:12 AM
Ryan's Avatar
Ryan
cheers, might have to try that, the autoglym stuff still shines even if u rub it off immediately.
Old Jan 30, 2007 | 09:18 AM
MWF's Avatar
MWF
Yeah if it's the Vinal & Rubber care spray I do know what you mean.
Old Jan 30, 2007 | 09:21 AM
Disabled Account's Avatar
Disabled Account
Try Amourall.........they do a low sheen version
Old Jan 30, 2007 | 12:20 PM
Ryan's Avatar
Ryan
cheers doug
Old Jan 30, 2007 | 12:28 PM
MATCOS's Avatar
MATCOS
Ryan try Poorboys trim restorer Gaz7 on here sells it and it's the bees knees
Old Jan 30, 2007 | 12:35 PM
scotty4130's Avatar
scotty4130
I used chemical guys trim gel, liking it a lot at the minute, got it from www.cleanyourcar.co.uk
Old Jan 30, 2007 | 12:36 PM
Ryan's Avatar
Ryan
everyone uses something different
Old Jan 30, 2007 | 01:14 PM
WD Pro's Avatar
WD Pro
BMW Gummi-Phledge
Non shiny, make seals look like new, stops squeaks, stops seals freezing, can cure leaks (from dry seals) and cheap as chips
Its what they recommend for the cabriolet seals and the seals on the pillar-less doors.
A tube will last you ages.
If your BM dealer looks at you with a blank expression (they often do) when you ask for it, go on any BM forum and do a search on the name, then go back to them with the part number …
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
