cut out on boost?
Old Jan 30, 2007 | 08:53 AM
sy.rst's Avatar
sy.rst
Default cut out on boost?
iv got a s2 rst, when i dive it hard the boost peaks bout 17psi and holds bout 10psi wiv my right foot planted it suddenly stops,rev couter goes mad then it back fire's then goes again. seams to only do this flat out in 3rd and in forth.the ecu has bn chiped and got a -31 actuator.
Old Jan 30, 2007 | 02:39 PM
JamboRS's Avatar
JamboRS
focus rs 1672
symptoms of boost cut
you sure its chipped?
or chip hasnt got a boost limter set
also a 17psi peak is a bit high for holdin only 10psi of boost
Old Jan 30, 2007 | 03:01 PM
SafeChav's Avatar
SafeChav
That clearly isn't chipped if its cutting out at 10psi in the higher gears.
Turn the boost down and take it for a rolling road set up, or it will go bang!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
