XR3I -->turbo by using std pistons skimmed 1mm?Ist long r
Old Jan 29, 2007 | 12:50 PM
jarnok's Avatar
jarnok
Default XR3I -->turbo by using std pistons skimmed 1mm?Ist long r
Has anyone experience using xr3i engine on turbo project?I thought that if skimming pistons 1mm is that enough for turbo use?Would the std pistons and rods take round 200 hv use long run?
Other issue is how is the turbo oil taken from engine and return?
Old Jan 29, 2007 | 08:22 PM
JesseT's Avatar
JesseT
This has been done time and time again in Finland. Because of the shape of the XR3i pistons, 1mm doesn't do much. If you take the entire dome away, you will have a piston that is exactly the shape and size as a RST piston. It will take 200hv, but certainly not as lightly as RST pistons which have been done with a different casting process.
The turbo oil feed and return is best and easiest done exactly like in a RST.
Old Feb 3, 2007 | 07:46 PM
steven botes's Avatar
steven botes
ford cvh pistons do not like boost , ive got the remains of a set in my garage. the ring lands are weak!!!!
if you are building on a budget(like myself due to buying a house and more recently a Scooby) , you could try what i have done.
use vw golf 1600cc pistons(80.950MM with really good ring lands)
use vw beetle bushes on the rods(the pins are smaller)
take 4mm of your block
remove 5mm off your head bolts
efi inlet manifold , gotech and 500cc injectors , t34 , vernier
the car to tune down here is a golf , so parts are readily available and bloody cheap
im aiming for over 200bhp
Old Feb 4, 2007 | 12:04 AM
Rick's Avatar
Rick
get some AE turbo pistons, cheap as.
Old Feb 4, 2007 | 10:04 AM
MarkN's Avatar
MarkN
I bought a set of new RST pistons and rods on Ebay for £20 some time back. It's well worth checking on there as they do come up regularly.
Matt Baxter
Sep 16, 2015 08:30 PM
Toe Knee
Aug 23, 2015 08:31 AM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
Billy_RS
Aug 3, 2015 08:43 PM
