4x4 cylinder head
Old Jan 28, 2007 | 03:26 PM
mk4gartrac's Avatar
mk4gartrac
Default 4x4 cylinder head
I have the head off for a bit of porting and new gasket is there anything els worth doing while its off or checking? also do i go for group A gasket or cometic multi shim gasket? also should i stick with standerd head bolts or go for a stud and nut kit from Burton power?
Old Jan 28, 2007 | 04:33 PM
Depends how much power you want, so long as 4x4 block you can use stud nut kit, just do usuall stem seals grind seats + three angle.
For a gasket the group a is good for around 400bhp, and will seal MINOR imperfections in block face as it is FIBROUS, metal will not, I use group a.
Old Jan 28, 2007 | 04:54 PM
mk4gartrac's Avatar
mk4gartrac
It is a 200 block and im not looking to go past 400 bhp so a group a it will be and i think ill go for the stud n nut kit to be safe i should be looking around 330-350bhp with 50bhp n os kit on top so shouldnt go past 400
Old Jan 28, 2007 | 07:10 PM
mk4gartrac's Avatar
mk4gartrac
Just lifted the head off and found the block is wire rung so do i have to replace the wires or can i just clean it up and put new headgasket on ? and can i still use a group A gasket or something els?
Old Jan 29, 2007 | 07:14 AM
Wire rung very old hat now, just clean up and fit new gasket group a will be fine, as as far as I know there are no specific gaskets to use with wires, latest thing is a ONE PIECE METAL GASKET.
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
