lowering problems
Old Jan 27, 2007 | 05:16 PM
16vzetec's Avatar
16vzetec
Default lowering problems
how comes my driveshafts hit the chassis at the front?
i got coilovers and they are well stiff and it wasnt even lowered that much!
how do people get on with low low cars?
Old Jan 27, 2007 | 05:35 PM
lewis_lisa's Avatar
lewis_lisa
not too good mate i had to raise mine back up as i couldnt get over the slightest of bumps without my exhaust scraping the ground
it does look good but 80mm was not practical
its now 40mm with koni adjustables
Old Jan 27, 2007 | 05:43 PM
nigel b's Avatar
nigel b
it shouldnt hit even if it was really low
have you got a bent track control arm putting your hub out of position
mines lower than that on coilovers and it never hits
Old Jan 27, 2007 | 07:26 PM
Moose's Avatar
Moose
With out soundin stupid, are you sure its your drive shafts that are hittin?
and not something else that is knockin? or can you actually see there close to the chassis.
Old Jan 27, 2007 | 08:12 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
i get a strange knocking noise ever since i lowerd mine ive now raised it back to standard height on the same shocks and springs as befor i put the lowering ones on and it still knocks any ideas guys?
Old Jan 28, 2007 | 08:52 AM
16vzetec's Avatar
16vzetec
yes its the drive shafts coz there are mrks on the drive shafts, the shafts are about 40mm thick i think, quite wide shafts and the touch the chassis, although they dont now as i highered to about -30mm.
it was only about -40 rst height b4.
zetec lumps are a tad hevier but no heavier than a rst lump.
i got light weight 4 brach instead of turbo too!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
