is there anything missing?
Old Jan 27, 2007 | 01:46 PM
fezzie2's Avatar
fezzie2
Default is there anything missing?
i cant seem to get a spark from my car so im just going to wire up the bare neccesitys to get it sparking, if i did this would it work? or do i need anything else including in it? I dont mid about fuel at the min because that all works fine, i just want to get it to spark.
if i do it like this and it still doesnt spark then does this mean my dizzy or ecu has gone?
Old Jan 27, 2007 | 04:43 PM
SafeChav's Avatar
SafeChav
Sounds like you've done it the hard way, if you strip out RS Turbo management wiring theres only about 7 wires to connect up in total!
Old Jan 27, 2007 | 08:07 PM
fezzie2's Avatar
fezzie2
which 7 wires would they be, i havent stripped the management out yet but will do this week so i can get it sparking...
Old Jan 28, 2007 | 04:40 PM
SafeChav's Avatar
SafeChav
Aren't you the one that was pm'ing me about your dizzy?
Old Jan 28, 2007 | 07:50 PM
fezzie2's Avatar
fezzie2
yeah thats me. im really strugling to get my car running, i cant fidure out what the problem is?????
Old Jan 29, 2007 | 12:26 PM
SafeChav's Avatar
SafeChav
Have you identified for definate yet if the pump runs when you crank the engine over?
Old Jan 29, 2007 | 12:56 PM
fezzie2's Avatar
fezzie2
it was hard to hear if the pump was working as my engine is loud when cranking, but im 99% sure it was working, and it felt like it was pumping when i held it....
Old Jan 29, 2007 | 01:01 PM
fezzie2's Avatar
fezzie2
just out of curiosity, should the number 1 pin on my fuel pump relay be giving out ignition live when the ignition is on? i thought pin 1 was an input signal from the wire coming from the coil via the tacho.
Old Jan 29, 2007 | 01:08 PM
SafeChav's Avatar
SafeChav
When you turn the key back you should be able to hear the pump run on for a split second usually.........
You second post ill have a look at later on in the middle of some stuff atm
Old Jan 29, 2007 | 08:02 PM
fezzie2's Avatar
fezzie2
i'll have a look to see if i can here the fuel pump run for a second when i turn the key back. that would be great if you could let me know about pin 1 on the fuel pump relay.
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
