Fit and tension tootheed belt
Old Jan 27, 2007 | 12:14 PM
2001ode's Avatar
2001ode
Default Fit and tension tootheed belt
Hi,
What is the reason that procedure for tighten is :
"Working in a clockwise direction" ???
Thanks for help.
Regards
Claude
Old Jan 27, 2007 | 03:48 PM
It is on an ECCENTRIC and the way to turn is clockwise to take up slack, other way will loosen.
Turn the eccentric adjuster till correct tension then use lock bolt in centre to lock it off.
Old Jan 28, 2007 | 02:19 AM
jon@work's Avatar
jon@work
If you adjust the tensioner in an anti-clockwise direction, the cam belt can rub on the thermostat housing, potentially causing premature failure of the belt.
Old Jan 28, 2007 | 02:26 AM
2001ode's Avatar
2001ode
Thanks to "Tabetha"
"jon", that's response i waiting.
It's clear for me, now.
Regards
Claude
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
cameron2
Aug 25, 2015 07:18 AM
borboyous
Aug 22, 2015 11:17 AM
lockie
Jul 31, 2015 10:03 PM
