Please help a newb, changing rear brake shoes
Old Jan 27, 2007 | 11:03 AM
Bello's Avatar
Bello
Default Please help a newb, changing rear brake shoes
Is there a guide anywhere?
It's on a mk2 mondeo, i've got the handbrake off so the drum spins freely but the drum won't come off, can anyone tell me what i'm doing wrong?
Thanks
Old Jan 27, 2007 | 04:13 PM
I thought though may be wrong that the mondy drums were held on by the bearings ?.
If the drum is trying to move ? ,it may have developed a ridge on the outside inner edge of the drum stopping it from moving off, hard way I'm afraid with force, you have taken out any screw holding drum on ?
Sorry can't remember if they are integral bearing housing or not.
ps remember to grind off any ridge when you do get them off.
Old Jan 27, 2007 | 04:34 PM
SafeChav's Avatar
SafeChav
You will have to undo the hub nut to release the bearing, and if it still won't come off then as above, chances are the drum is grooved!
A big screw driver/pry bar should see it off!
Old Jan 27, 2007 | 05:24 PM
Bello's Avatar
Bello
sorted it now...
The drum does come off seperate to the hub, there's a little service hole type thing on the back of the drum backplate that you can stick a screwdriver in and adjust the postion of the shoes so that the drum comes off over any ridge
Thanks u2
Old Jan 27, 2007 | 05:26 PM
lukes1's Avatar
lukes1
if worst comes to worst use a slide hammer with the grubscrew left in, if ur changing the shoes any way the dont worry bout mullerin' them
lukes1's Avatar
lukes1
ok ignore that
original
Apr 28, 2026 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
