run out of petrol then everything went wrong
hiya guys.... just bought my rs turbo s2 recently and the previous owner didnt tell me when the tank shows a quater its empty lol. so i ran out of petrol put some petrol in then about 20 yards away it cut out.... everytime i try to start it it runs for a second and cuts out....now if i press the gas down to full it will run like its on 1 cylinder and back fires with black smaoke. what could it be...? dizzy cos its held together with a cable tie and we messed with it, air/fuel mixture, injectors? any ideas?
Sounds like the fuel system may need bleeding to remove air and it will now need a new fuel filter
Have a look at these threads for further ideas
https://passionford.com/forum/viewtopic.php?t=242152
https://passionford.com/forum/viewtopic.php?t=239854
https://passionford.com/forum/viewtopic.php?t=239864
Keep us posted
Keep us posted
Read a few of those links above.
One should explain about cracking off (open) the banjo fittin on the fuel supply.
You still having problems ?
Get the filter changed first IMHO
You feinately sure its out of fuel mate.
The pump will sound a lot more prominent and louder if its no fuel, cos theres no load on the pump!
And thats a point while i think of it, you sure the pump is running?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
