Engine is back in.............
Old Sep 6, 2004 | 06:34 PM
CombatSapph's Avatar
CombatSapph
Default Engine is back in.............
.From this:-
To this:-
To finally this:-
Nothing major - replaced every oil/water gasket on the bottom end (front crank shaft, rear crank shaft, aux pulley, sump gasket, distributor o ring seal, water pump gasket) - guys that built the engine hadn't used quality gaskets (instant gasket in some cases - eurgh!) so I thought I'd do it properly myself using Cometic AFM gaskets where I could (if it's good enough for a Focus WRC, it's good enough for me!).
Well chuffed with the results - donw around 200 miles in it so far and it hasn't dropped a single drop of oil or coolant.
Whilst the engine was out, I finished up some interior bits as well:-
Namely fitting the air/fuel ratio meter in the dash and the corrsponding Lambda sensor in the exhaust manifold. I think the AFR compliments the ignition barrel relocation and the push button starter nicely. Gauges at the top (left to right) are water temp, oil pressure and voltmeter. A boost gauge (an expensive vacumn gauge atm is sat in a Nomad A pillar pod. Remaining space is being saved for a nitrous pressure gauge
Now all I've got to do is get the courage up to spray the dash matt black!
Old Sep 6, 2004 | 08:17 PM
RobS's Avatar
RobS
Old Sep 6, 2004 | 08:22 PM
Rich@rd's Avatar
Rich@rd
Very nice mate
Old Sep 6, 2004 | 08:48 PM
cossiemen's Avatar
cossiemen
Whassup
well done
Old Sep 6, 2004 | 09:08 PM
paulp's Avatar
paulp
looks smart,makes a change from seeing a cossie engine in there
Old Sep 6, 2004 | 11:33 PM
Chipperx2's Avatar
Chipperx2
Old Sep 7, 2004 | 12:20 AM
Disqaulifed driver's Avatar
Disqaulifed driver
From: Somewhere, Drives: the mk3 look its there>>>>>>>>>>>>> Eats:t
looks well cool mate
top job
Old Sep 7, 2004 | 10:12 AM
Notorious_G's Avatar
Notorious_G
lookin good
Old Sep 7, 2004 | 12:39 PM
bbigman2000's Avatar
bbigman2000
nice job bro, is that a 2 litre pinto ? what sapphire is it ? 2.0glsi ?
Old Sep 7, 2004 | 04:25 PM
CombatSapph
Yep - bored out to 2.1, high torque cam + flowed head, MSD chip, Burtons lightweight steel flywheel etc - 150bhp.
Car is based on a D reg 2.0i Ghia Sapphire - few pics of what it looks like now:-
Old Sep 22, 2004 | 05:18 PM
dutchcos's Avatar
dutchcos
Looks very nice!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
