fiesta 1.25 engine wanted
pleeeeeeeeeeeeeeease
norfolk suffolk area please maybe a 1.4 too if i get stuck, whole car would do if cheap enough
cant reply so ill update
1.6 isnt cheap tax and the cars a burgandy 4 door so ive no interest in 'doin it up'
I think that you should go for a 1.6 Zetec S Engine - gearbox and loom + ecu and everything you may need : Air con compressor, Power steering pump, alternator the full works. Only done a warrented 55K Got full service history - and even had a cambelt in the last 200 miles !!
Can do the Fiesta Zetec S brake conversion also for you !!
Which i just happen to have - maybe even be able to see it running !!
If i can figure out how to override the crash cut off switches !!
Let me know if you are interested.
