HELP I NEED A BOTOM END
Old Jan 21, 2007 | 09:37 PM
khanny's Avatar
khanny
Default HELP I NEED A BOTOM END
4 A ERST 87 S2 JUST BOUGHT A BRAND NEW TURBO LIKE A DIV EVERY1 TOLD ME ON HERE DO A PRESURE TEST TURNED OUT TO BE PISTON RINGS IN NUMBER2 PORT SO BOTTOM END NEEDED URGENT CHEAP AS WELL GUYS AS SKINT NOW
Old Jan 21, 2007 | 10:06 PM
antony215's Avatar
antony215
Escort Rs Turbo
Dont need to be from a 87 mate can be from any escort rs turbo. I take it you didn't do a pressure test till after you bought the turbo then and how do you know it's rings was the gasket ok??
Old Jan 21, 2007 | 11:22 PM
khanny's Avatar
khanny
YE GASKET WAS FINE THE MECHANIC SHOWED ME ALL THE OIL IN THE OUT LET EXAHUST PORT ON NUMBER 2 AND HE SAID THAT WHEN I TAKE THE OIL CAP OF THE TOP THE ENGINE SHOULD CUT OUT SO THERES NOT MUCH COMPRESION OR SOMERT
ANY IDEAS HOW MUCH IM EXPECTED TO PAY 4 A SECOND HAND BOTTOM AND WERE FROM CHEERS
Old Jan 22, 2007 | 06:04 PM
SafeChav's Avatar
SafeChav
TOLD YOU SO
Thats well gutting mate
Have you ACTUALLY done the compression test now - the reason i say that, is oil in the exhaust port could be caused by other things.
Old Jan 22, 2007 | 07:30 PM
khanny's Avatar
khanny
YE DONE NUMBER 2 WAS WELL DOWN GOT A FRST BOTTOM END SO ANY HELP ON RIPIN THE ENGINE OUT AND PUTTIN THE HEAD ON WOULD BE GREAT CHEERS
Old Jan 22, 2007 | 11:25 PM
SafeChav's Avatar
SafeChav
How much did you pay for the FRST bottom end just out of interest.
Wouldn't really know what to say, if you can get the old one out the FRST one will fit straight back in.
Get yourself a Haynes is probably the best thing i can say.
Old Jan 23, 2007 | 09:46 AM
khanny's Avatar
khanny
60 M8 the blocks already out, some1 says if the abs pumps on i will have trouble
Old Jan 23, 2007 | 01:48 PM
antony215's Avatar
antony215
Escort Rs Turbo
Your taking a bit of a risk mate if you aint heard it running the ABS it's just a pain because it get's in your way when you putting the engine/box in
Old Jan 23, 2007 | 08:10 PM
SafeChav's Avatar
SafeChav
fuck sake i can never find cheap bottom ends. I agree though, a second hand bottom end could be as bad/worse than yours.
And i was going to advise dropping the engine and box, i duno how the fuck people refit engines with the box in situ, i always struggle enough to get the box lined up in the clutch plate spline when re-fitting with the engine dropped
Old Jan 23, 2007 | 08:43 PM
Craigb's Avatar
Craigb
Dont say that !! Ive got the engine already sitting in my living room and the gear box sitting in the car already to go back together.
Old Jan 23, 2007 | 08:46 PM
SafeChav's Avatar
SafeChav
Seriously though I dont know how people do it (without damaging shit anyway), theres not that much space for manouvre in the bay and i just generally consider lining input shaft splines up quite tricky
Old Jan 23, 2007 | 09:03 PM
gup's Avatar
gup
take the bottom pulley off this gives you a bit more room and the fit the engine in at an angle i always leave the inlet on and fit the turbo after
this is how i do all my cvh engines piece of cake with a bit of swearing involved lol
also put a jack under the g/b to help you tilt it or raise it
Old Jan 23, 2007 | 09:04 PM
gup's Avatar
gup
ps take the bonnet off it helps to get things round the back and gives you more room
Old Jan 23, 2007 | 09:13 PM
SafeChav's Avatar
SafeChav
Yer its the swearin bit and everything else involved with it that makes it annoying
I'd much rather drop the box out with it i think
Old Jan 23, 2007 | 09:17 PM
gup's Avatar
gup
true but its more things that you have to remove so it will take longer dont take long at all my way oh ive done shit loads tho so its a bit easier for me
Old Jan 24, 2007 | 03:58 PM
IANS2RST's Avatar
IANS2RST
if u use a proper engine lift then its really easy with the box in place.
I use a block & tackle attatched to an rsj
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
