Help think I've bent a valve!
Old Jan 21, 2007 | 04:56 PM
escortcosrs's Avatar
escortcosrs
Default Help think I've bent a valve!
Hi guys
My headgasket went on my cosworth last week so over the weekend I changed the gasket.
Anyway I started the car up and it sounded fine and ran smooth straight away, let it idle fo a min or two and noticed the pulley making a bit of a noise. So stopped the engine and the cambelt was a little tight. As I undid the tensioner the belt slipped off one of the top pulleys, so I realigned it thinking I had it just as before started it up and now getting a rattle from the top of the engine near number four cylinder on the inlet side. Its very loud and I defo wouldn't want to drive it or let it idle for any period of time. I have checked and double check the timing and I know its spot on. The car runs on all four cylinders and idles ok. I think I might of bent 1 valve as its definitely running on 4!?
Any idea?
Thank you
(On another note iv never seen a headgasket go so bad it was a group A version I have replaced it with another group A but the old one had split in two places)
Old Jan 21, 2007 | 05:08 PM
Alvyn's Avatar
Alvyn
take the belt off again and re-check your timing up again,once done check the compression and see if it's low on the certain cylinder in Q as if it was a bent valve it wouldn't be running that smooth and on 4 cylinders!
I think it maybe a tooth out which would cause the clacking noise your hearing!
Old Jan 21, 2007 | 05:35 PM
escortcosrs
Alvyn just done that and its sorted!
Thank you very much for the reply
Old Jan 21, 2007 | 05:48 PM
Alvyn's Avatar
Alvyn
no probs glad it's sorted
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
