nikasil coating
the bores are not coated with nikasil..
the whole bore is fitted with a liner made from nikasil..
think its about 1600 quid to get it done to a 20 block..
could be wrong?
could be wrong?
I would say they are alloy sleeves coated with nikasil or may me a steel sleeve coated with nikasil.
wasn't this the bore coating on the jag V8's from 1996 and used in the porsche 928 back in the 80's and 90's, that never worked for either company, thats why porsche 928's use more oil than petrol, and jaguar gave up with in about 2001 and went to steel liners, if it is the same bore coating, then if Jaguar and porsche can't get it right i would leave well alone!!!!, the idea is good but the practice is not good, for some reason i believe it worked in bike engines though.
Don't ask - I don't know
Originally Posted by gurnE
Originally Posted by Mr S1
Why would you do this ? What are the benefits ?
don't know about the 911 but in the last of the 928's when they went to 5.4 it got that bad that any cars taken is as a part ex at a porsche dealership, got sent back to the factory to have a new engine put in, or at least i believe thats what happend,
Alex
Nikasil is a trademarked electrodeposited oleophilic nickel matrix silicon carbide coating for engine components, mainly piston engine cylinder liners. It was introduced by Mahle 1967, initially developed to allow rotary engine pistons to work directly against the aluminum housing. This coating allowed aluminium cylinders and pistons to work directly against each other with low wear and friction. Unlike other methods, including cast iron cylinder liners, Nikasil allowed very large cylinder bores with tight tolerances and thus allowed existing engine designs to be expanded easily, the aluminium cylinders also gave a much better heat conductivity than cast iron liners which is an important factor for a high output engine.
Gotta love a wikipedia quote
http://en.wikipedia.org/wiki/Nikasil
jonfoc
Sep 11, 2015 04:46 PM
