Cam questions
took the cam out of my turbo head before and basically, its goosed. lobes are well worn
i've got a cam out of a fiesta turbo, i know there EFI and the ports on the heads are different. but....
will thr fiesta turbo cam fit my MFi head? and also the cam dosent have a ford stamp on it anywhere is it possible it is an aftermarket one?
cheers boys
cheers boys
exact same cam mate
it aint got no ford stampings on?? its usually in between some of the lobes.. if not look on the arse of the cam and see if there is any markings there? numbers or letters..
no mate, the one out of the mfi head had the ford badge in the middle, but this just has a few letters and numbers. and also the cam lobes seem like they have more of a peak to them if you get me
Whats the numbers on the cam?
And as far as Ford cams go, MFI XR3i's & RST's share the same cam, and EFI XR3i's, XR2i's and RST's share the same cams. EFI cams were re-worked but are fully cross compatible, so an EFI cam will produce a little more power
Mc5506
Oct 5, 2015 09:57 PM
