Pictures of my Escort RS Turbo
Finally managed to get some pics of my rst.
I have also put the car's spec below:
Engine: Low compression bottom end. Farndon steel crank, arrow steel rods, accrelite pistons 0.5mm oversize, A.R.P rod bolts, A.R.P flywheel bolts, new main and big end bearings and thrust bearing, new oil pump, new water pump. Cosworth fuel pump. Head ported polished and gas flowed as far as possible. Inlet manifold ported to match head. 1mm oversize valves 1 piece steel valves from Paul Harvey, twin valve springs with titanium valve caps and bronze guides, piper T285 camshaft, vernier pulley, brand new tappets, new cam belt and tensioner. Hybrid T3 turbo with 360° bearing and -34 actuator. Magnacore Leads. Mappable 5th injector, pace charge-cooler, pace alloy radiator, pace intercooler, bailey swirl pot, aquamist water injection, flamer kit, 3 1/2 inch mongoose exhaust system. Samco hose kit for boost pipes and water pipes, Bailey twin piston dump valve, hearts and diamonds chip. chrome rocker cover, boost inlet pipe, Bailey header tank, Bailey oil separator, fuse box cover, break reservoir cover, turbo cover and 1 off under bonnet RS plates. AP 4 paddle clutch and LSD gearbox.
Bodywork and exterior: 1990 spec front bumper with Mondeo splitter, 1990 boot spoiler and rear bumper. De-locked and de-badged. 16-inch Cosworth rep wheels with yokohama AR520 tyres 205/40/16. Uprated Cosworth front brakes drilled and grooved discs, mintex pads and up-rated Cosworth callipers. Rear disc conversion, Cosworth rear callipers discs and pads. Uprated braded brake hoses front and back. Koni adjustable suspension. All round polly bushes. Single wiper conversion.
Interior and Security: 1990 interior absolutely mint like the day it came out of the factory, 4 spoke RS steering wheel. Boost & oil pressure gauge. Charge temperature digital display unit. Ait to fuel mixture computer. RS turbo floor mats. Clifford concept 600 alarm & immobiliser - thatchman approved, extra separate immobiliser.
Performance: 240 bhp @ 18 psi
Free image hosting by http://www.holdthatpic.com/
cheers guys will be out to play in spring time jamie
i was lucky enough to buy the car with this work done im sure some people on here will know the car. i have some recipts for engine adding up to Ł12500 which is pretty scary im sure some guys on here have spent a lot more
dont want speakers pete m8 engine sound to good lol
here are a few more pics
Originally Posted by marky_g
do i find ur charge cooler gets blocked alot?
Originally Posted by DanRSturbo
Nice looking motor you got there, although, in the spec you say it has a pace chargecooler and a pace intercooler
Originally Posted by zippyobrien
thats not an intercooler lol, its the rad for the water from the charge cooler,
youve got a charge coole set up, no inter cooler there,
bloody bungle,
you could fit an intercooler to if you really wanted, some bloke with a series one did it, fitted it alle scooby style behind the inlet and had a scooby bonnet vent fitted,
muz
Aug 16, 2015 12:57 PM
