mk3 escort PROBLEM
Old Jan 18, 2007 | 12:42 PM
djclaw's Avatar
djclaw
Default mk3 escort PROBLEM
hi i have a mk3 escort 3 door estate which has a mk3 1.6 fiesta sport cvh engine in her and a mk5 escort gear linkage. i just put a gearbox from a mk5 escort 1.4 cvh ito it and the drivers side driveshaft is too short by around an inch.
should i get a driveshaft from a mk5 or what ? ? ? ?
Old Jan 18, 2007 | 05:48 PM
SafeChav's Avatar
SafeChav
Thats odd! Should drop straight im sure? How do you mean its an inch too short exactly?
Old Jan 18, 2007 | 05:59 PM
MarkN's Avatar
MarkN
Is it a three bolt strut top or a single bolt strut top? What year is it?
The three bolt four speed cars had a drive shaft about an inch longer than the later cars. Is the end of the B5 box almost touching the inner wing on the passenger side? If it is then the driveshaft is right but the engine mounts are wrong. Fit the right mounts and it will move the engine an inch closer to the drivers side...
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
