Escort RS Turbo misfire
i have just got an rs turbo and it is misfireing if i put my foot down in 4th and 5th gear. once i get past about 3500 rpm it stops doing it. its really annoying. DOES ANY ONE KNOW WHY????? PLEASE SOMEONE HELP
Hello. I have misses too if that you mean.
Can be many thing. I hope you are good at engines.
Bad plugs
Bad leads
Bad rotor or dizzy cover
Cold start valve leaking
and much more but I will tell you what my problem was.
My car misses and would not run correct at full throttle. After many many houers in the garage I figure out that the hose from the air unit was old and collapsed when the turbo started to boost. When I tooked it of I could see from the hose and from the air unit a lot of oil. That oil comes from the ventilation located on top of the rocker cover or the turbo itselves.
I plugged the ventilation and made a steel constuction between the unit and turbo. Cleaned from oil and fitted the stuff.
No misses and the cars flyes now. Good luck over there.
Mvh Butchi
Bad plugs
Bad leads
Mvh Butchi
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
