water pipes on the turbo
Old Jan 14, 2007 | 09:24 PM
jimmylaud's Avatar
jimmylaud
Default water pipes on the turbo
hi was just wondering where i can get new water pipes for my turbo and how much they roughly are thanks alot
Old Jan 14, 2007 | 09:30 PM
djmillsy's Avatar
djmillsy
Fife Radge
http://www.samcosport.com/samco.asp?make=ford
Old Jan 14, 2007 | 09:39 PM
jimmylaud's Avatar
jimmylaud
i didnt mean they ones meant the metal ones that bolt onto the turbo cheers for the help
Old Jan 14, 2007 | 10:01 PM
djmillsy's Avatar
djmillsy
Fife Radge
proberly from a turbo place no idea about price tho
Old Jan 15, 2007 | 05:02 AM
Wazzzer's Avatar
Wazzzer
don't bother, just run it without the water cooling
Old Jan 15, 2007 | 07:46 AM
rst steve's Avatar
rst steve
I had problems with the water pipes on my turbo when i replaced it. What i did was take the pipes to my local hydraulics firm and they took out the old rusty pipes and replaced them with new ones as the pipes are sweated into the fittings so as long as the fittings are ok they should be able to do it. Only cost a fiver per pipe and they came back with straight pipes so got to bend them as i wanted got a bit more clearance on the bottom one. If you are stuggling to find a firm that will do it if you send the pipes to me i could get them done for you and send them back.
Old Jan 15, 2007 | 01:09 PM
jimmylaud's Avatar
jimmylaud
thanks alot steve ill find out if anyone around my area does that if not ill give you a shout if thats ok, do you know where you can get new banjo bolts from ?
Old Jan 15, 2007 | 01:18 PM
SafeChav's Avatar
SafeChav
The bottom pipe on mine was broken sometime before i acquired the engine, and believe it or not, its got a new copper pipe soldered to the banjo
Never had a problem with it, how im not quite sure??
Old Jan 15, 2007 | 01:44 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I might have some in the RST parts archive!!
I will go look when I get a chance.
They are fooking expensive from Ford, but still available. I have steel braided hoses on mine, but no point really, better to stick with standard stuff, they were designed for it.
Old Jan 15, 2007 | 01:49 PM
SafeChav's Avatar
SafeChav
Christian and Beccy, you might be able to tell me, ive seen just the banjo's by themselves, so you can clamp rubber/silicon pipes onto them, my mate had some on his R5 that was running a T3 roller, any ideas who makes them?
Old Jan 15, 2007 | 02:01 PM
stuartrsturbo's Avatar
stuartrsturbo
I got a top and bottom water feed pipe from Dan from Rapid Ford.
Old Jan 15, 2007 | 02:08 PM
jimmylaud's Avatar
jimmylaud
i tried soldering copper pipe to my banjo nolts but it only lasted two weeks
cristian and beccy if you find any give me a shout and i would buy them of you thanks for the help
Old Jan 15, 2007 | 02:42 PM
craigos's Avatar
craigos
ive got a front 1 thats good in my garage
Old Jan 15, 2007 | 03:07 PM
jimmylaud's Avatar
jimmylaud
craigos r u selling it ? thanks
Old Jan 15, 2007 | 03:24 PM
craigos's Avatar
craigos
yes mate i would.
do make me a offer i pmd you
Old Jan 15, 2007 | 03:31 PM
jimmylaud's Avatar
jimmylaud
perfect how do you get that msg ? cheers no very good with computers
Old Jan 15, 2007 | 03:35 PM
jimmylaud's Avatar
jimmylaud
just found out how to do it there
Old Jan 15, 2007 | 04:03 PM
Mike at Corby Motorsport's Avatar
EDITED BY WEBTEAM
Oct 9, 2015 07:38 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
robbo9006
11
Sep 1, 2015 02:10 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
