still backfiring
right changed the leads timing belt rotar arm disturbuter cap sarted the car up and itsw still backfiring like fuck its onlt doing it when the turbo comes on the dumpvalve seems to be opening when i give it thottle could the dumpvalve be fucked on it or the turbo
i think so its standard boost it is a bailey could the timing be 180 degress out
you think the turbos ok i noticed ive got a cracked rasdiator hose but theres no reek out the back of it just bang bang
her father thinks it is its backfiring when you come on full boost its running .5 bar boost could the dumper be fucked its opening when you rev it up but its not moving ih and whoever done the ht lead last put them on 1243 on the cap
Thats why i was asking the boost it runs. Have you got a gauge in the car or is 0.5 bar what youve been told.
I doubt its the dump valve, the primary piston closes back up as soon as you start boosting cos theres no vacuum.
Who the fuck put them on, they need a slap
Is the wiring connector on the dizzy on the top?
the wiring is on the dizzy at the top the boost gauge in the car says .5 bar boost on full boost i was thinking of taking the dumper off cause its shit i never put it on
Well that rules out the boost limiter and ignition system in general, if you had the fault as a result of loss of ignition the rev counter would be dropping to 0 until the missfire/backfire has cleared.
Try checking the timing as Alex suggested
double checked the rev counter all is good took the dumper of and was still doing just nipped in for dinner then where going to redo the timing and see what happens just hope i can get it sorted walking everyway is crap could it be a sticking valve?
well its still doing the distubutor seems a bit suspect on it tho it was clicking away for no reason so im going to get a new one and try that lets hope this sorts it
If its the distributor cutting the ignition out the rev counter WILL be doing some crazy stuff, end of story.
The cap/rotor arm could affect it, but you say you've changed them yea?
And as for the timing, the silver ecu behind the heater box, theres a small vacuum pipe running to it
right the disstrbutor was shagged got a new one it starts alot better even has the shroud on it its still backfiring but not as much checked the sparkplugs there like new one was a bit dirty so replaced it in cylinsder 3 im now leaning towards a sticking valve in cylinder 3.
thats the timing belt changed set up new dizzy, rotor, leads, disturbuter, got a coil to try on it tomorrow just hope that sorts it the manifold is still glowing red tho
so do you diconnect it from the ecu and why do you do that
The dizzy wasn't at fault if its still back firing!
You need to disconnect the vacuum pipe to stop the ECU from altering the timing, disconnecting the vacuum pipe means you can set up the Timing without out any alterations.
This is the same on carbeurettor cars, the dizzy's on them have vacuum advance
Originally Posted by djmillsy
ok will do went to start it to move it out the way and there was a clickingsound coming from the distrubutor area any ideas
amal valve sits on the top of the gearbox just under dizzy, with 3 pipes one from turbo and one going to actuator, it controls boost, should click when you turn on ignition.
Sounds like You really need to get it too a rolling road, you could be changing things forever and never get anywhere, could be something as daft as the gasket at the throttle body, but would be best to take it to someone decent to have it checked out, may work out cheaper in the end rather than just changing random parts.
Jay
Jay
Originally Posted by craigos
swap the dizzy mat be th wires in it breaking down iv had it twice then time it up
Ahhhhhhhhhh................
Your metering head might be fucked.......when i first dropped the engine in the cabby i picked the knackered metering head out of the 2 i had, it was overfuelling its tits off on one cylinder, it drove fine but you only had to dab the throttle and it back fired, it was obscene when you drove it LOL i was pissin myself
