loose front bumper
can these bits be replace on front bumpers
[/img]
i took my front bumper off 2 day 2 find 1 side perfect but the other side broken
if they can be replaced do ford still stock them
[/img] i took my front bumper off 2 day 2 find 1 side perfect but the other side broken
http://cgi.ebay.co.uk/FORD-ESCORT-RS...QQcmdZViewItem
You should find that'll do the job for you mate. I've just received mine in the post today. Although listed for a Escos, I've checked with the seller who has confirmed they are exactly the same for the Sapphire. I'm gonna have a go at changing mine tomorrow.
If your car is a 2WD Sapphire then the kit that is mentioned in the above post will not work mate. (judgeing by the brackets on your bumper I'd say yours looks like mine which is 2WD.
The brackets are not available anymore from Ford or the guy on ebay cosworthshop-com
I got dicked by the guy who you've just brought your brackets from paul, those won't fit without cutting and plastic welding etc etc.
This was the case for my 1988 2WD Sapphire anyhow.
What I had to do in the end is take the brackets to a plastic welder and have then welded back together. The chap who did mine did a great job mate. I'm fairly certain that will be the cheapest option also.
Check this thread I made on the RSOC when I was rebuilding my front bumper. http://bbs.rsownersclub.co.uk/showthread.php?t=100052
If you do want to order new parts for your bumper mate, here's the finis codes for everything apart from the big T Brackets as show in my photos above.
Phone Ford up and give them the codes below.
6169188 Reinforcement x 2
6143375 "O" Ring' x 2
6169187 Retainer x 2
1465244 Bolt - Hex, Head, M8 x 40mm... x 2
1001467 Washer - Cup x 2
6151261 Retainer x 2
6178615 Bracket - Support, RH x 1
6179271 Bracket - Support, LH x 1
Here's a screenshot I took from my Ford Microcat parts program on my computer
nice thought this job was going 2 b a pain in the ass
when i looked on cosworth shop on e-bay didnt think it looked right,
so it a easyish fix, r the parts u listed the 1s i need?
It's piddling down here, so haven't had chance to get under it yet today.
Nov 3, 2015 04:08 PM
